Mustang MD1100-SE chassis dynamometer
For sale is a Mustang MD1100-SE 2WD eddy current chassis dynamometer:
http://www.mustangdyne.com/mustangdyne/products/chassis-dynamometers/2wd/?prod=MD-1100+Series
http://indianapolis.craigslist.org/pts/4171522247.html
This is being sold as a complete plug and play package and includes:
- Dyno with above ground rack to strap cars to. It also has the necessary provisions for mounting in ground (as it was with the original owner).
- Two ignition pickup systems
- Weather station -- temperature, humidity, barometric pressure
- Single wideband oxygen sensor
- Ventilation system, hoses and exhaust fan
- One 42" general air fan
- Two high output scroll-type fans for radiator/inlet
- Control center with flat screen monitor and PC
- Straps, wheel chocks, etc.
- All original manuals, documentation, etc.
** Four post lift in pictures is NOT included **
Dyno features:
- Has an eddy-current load cell which can hold the test vehicle at specified RPM/throttle position/road speed; great for tuning stand-alone ECUs
- Programmable test cycles - perfectly suited for emissions and diagnostic testing.
- LOW usage; only 53 hours - 1900 miles on the clock.
- Software is extremely flexible, program your own test cycles
- Tune FWD, RWD cars as is; add-ons are available from Mustang Dyne for motorcycle and AWD
Cons:
- Will need brake pads soon, they're getting low (Mustang quoted $400)
- Rarely but occasionally puts out weird HP/Torque numbers when doing power pulls; not sure why but a subsequent run returns the values to normal.
This has been a great tuning and diagnostics device at our shop; when we bought it there were 29 miles on it, so really it's barely been used, not even two work weeks of total time on it. We've had a 700HP RX-7 on there and it held it for ECU tuning, no problem
We can uninstall it and get it to our front overhead door; purchaser will have to arrange for loading and transportation.
Asking $23,500 OBO. Contact us here or at [email protected]. More hi-res pictures are available. Serious inquires only please.
