E46 M3 Track Car For Sale (GTS3/4 | TT3) (SOLD)
Posted (edited)
My E46 M3 track car is up for sale.
Some of you may have already seen the build thread(s) for this car - If not, see the links below.
m3forum
http://www.m3forum.net/m3forum/showthread.php?t=434202
Bimmerforums
http://forums.bimmerforums.com/forum/showthread.php?1980648-disapr-e46m-track-build
m3post
http://www.m3post.com/forums/showthread.php?t=800559
Parts/Modifications Section (Detail)
Body
  • Roll cage was fabricated by Lucas Racing - All tubing is 1.750 x .090 Steel, TIG or MIG welded depending on access.
  • Interior paint & body was done by Richey Collision - Metal was etch primed and painted with single stage DuPont Alpine White.
  • BMW CSL Carbon Fiber Roof - This is one of the last OEM BMW CSL Roofs and includes black CSL rails. The roof was bonded using SEM 39747.
  • BMW OE Windshield - New
  • Five Star Bodies Polycarbonate Rear & Quarter Glass - All windows are attached with screws that are tapped/threaded into the body.
  • Five Star Bodies Rear Window Brace w/Custom Mounts
  • Bimmerworld Carbon Fiber Diffuser
  • Bimmerworld Carbon Fiber Headlight Blanks
Engine/Performance
  • Zionsville E46M Competition Cooling Radiator w/SPAL Fan
  • BMW Motorsport Thermostat
  • VAC Billet Racing Oil Filter Housing
  • C&R Racing Remote Filter Housing w/Custom CNC 6061-T6 Aluminum Mount
  • SETRAB Oil Cooler
  • SETRAB Power Steering Cooler
  • GoodRidge PTFE Oil Lines & AN Fittings
  • Turner Solid Aluminum Engine & Gearbox Mounts
  • Bimmerworld Race Exhaust with straight pipe
  • Remote WIX Racing Filter
  • EPIC Race Tune
  • AFE Stage II Intake w/dry filter/new MAF
Suspension
  • MCS 2way Dampers w/Coil-Over Rear
  • Hyperco Coils 650 Front | 375 Rear
  • Hotchkis Sport Sway Bar Set
  • Ground Control Adjustable End Links
  • Turner Solid Aluminum Bushings & Spherical Bearings
  • Ground Control Spherical Rod Ended Control Arms
  • Turner Subframe Reinforcements Front & Rear - The rear subframe is also tied to the cage.
  • Mason Engineering STB
Interior
  • Custom Carbon Fiber Switch Panel
  • Push Button Start w/GTR Start Button
  • STACK Gauges - Oil Pressure, Oil Temp, Water Temp
  • AiM SOLO DL w/CANBUS Connection
  • Custom Carbon Fiber AiM SOLO DL Mount
  • RaceTech 4009WHR Driver Seat & RaceTech 4009W Passenger Seat
  • SCHROTH Profi II-6 HANS Driver & Profi II-6 Passenger
  • CAE Ultra Shifter
  • VAC Seat Mounts
  • WorksBell Quick Release w/Machined/Pinned Steering Shaft
  • Sparco Steering Wheel
  • Mason Engineering Clutch Pedal
  • Turner Pedals
  • BSCI SFI 45.1 Padding
  • 4 Pole Battery Disconnect Switch
  • SPA 4L Mechanical Fire System
General
  • Apex Arc8 Wheels
  • StopTech ST40 Brakes w/Stainless Lines - PFC11 Front pads & PFC01 Rear pads
  • Hoosier R6 Tires
  • Braille Carbon Fiber Battery
  • Braille Battery Mount
  • PAINLESS Stranded Copper Battery Cable w/Monster Terminals
  • Techflex Braided Sleeving
  • Heater Core Delete
  • CDV Delete
  • A/C Delete
  • Parking Brake Delete
  • Emissions Delete
  • Turner Nylon Tow Hooks
  • Turner 90mm Studs
  • Turner Spacers 5mm F 10mm Rear
  • Machined Rear Hubs to Clear Spacer
  • All new control arms, bolts, axles, seals, hoses etc
  • AMB (MyLaps) Transponder - Hardwired
All items listed and the associated accessories are included.
Description
Weight: 2807lbs with a nearly empty fuel tank and no driver.
RWHP: 296 on a DynoJet
This car has been completely disassembled, inspected, cleaned and reassembled with great attention to detail. All bolts, seals, axles, control arms and bearings have been replaced with new OEM BMW components. All suspension bushings have been replaced with Turner solid aluminum bushings or spherical bearings. All systems/components are in perfect working order with zero issues.
During the build, all fluids were changed including: Engine (Castrol TWS 10w60), Transmission (Pentosin MTF2), Brake System (Castrol SRF) and Differential (BMW Motorsport 75W-140). Since the initial build, all usage has been logged and fluids have been regularly changed.
All engine maintenance items have been addressed – The VANOS system has been inspected and no issues were found. The VANOS filter has been changed, timing chain tensioner has been replaced and engine valves have been adjusted. The engine has new spark plugs, accessory belt, coolant/power steering hoses and new throttle position sensors and MAF sensor among other items.
The engine and drive train have 74k miles. All other wear related items have been replaced and have approximately 2k miles.
Since completing the build, the car has done 8 track days and one NASA TT3 race, placing second both days against a very capable advasary. The Hoosier R6 tires and brake pads only have 8 short TT sessions on them from the race in September.
Everything was throroughly tested and fine tuned over the summer, performing flawlessly at NASA. The car is dialed in and very forgiving to drive - for those of you that are familiar with Texas World Speedway, my best lap from the NASA TT race was 1.52 CCW on R6's with no aero.
This car meets all rules for NASA GTS and TT3, and was specifically built to race GTS3/4. I have most receipts for large items and can provide full documentation on the usage and maintenance.
Obligatory “Why are you selling it?” - Focusing on new goals and opportunities.
SOLD, thanks!
Pictures
Larger photos can be found on my Flickr site
http://www.flickr.com/photos/jeremyshanejohnson/sets/72157637555992766/with/10800887193/
Thanks for looking
I was really impressed with the cleanliness and pace of this car when it was out at the NASA-TX TWS event. Hope it doesn't sell because I want to see more of it! Or make sure the new owner does NASA stuff...
Thanks Ken - If the new owner isn't a NASA member, I'll make them sign up before taking the car
GLWS
Hopefully this is just a typo: All tubing is 1.750 x .090 Steel (could be/should be .095)
GLWS
yes, it's a typo.. good catch.
Phew! Beautiful car. Wish I was rich...or didn't care about living in a carboard box.
good man - hope you bring your new car / opportunity / whatever else out with us in the future too
  • Members
Saw this car at a NASA event at TWS a few months ago. AMAZINGly clean and thorough build!!
  • 1 month later...
Thanks
