Stand on the Podium Now! Championship winning Camaro Z28
FOR SALE: $29,500. 2001 Z28 Rocky Mountain Championship Camaro
This is a fully prepared, professionally built race car. A FAST, FUN, RELIABLE, easy to drive track car. Qualifies as NASA American Iron, ST2, Time Trial or SCCA T-2, A Sedan, ITE/STO or as an excellent track day car.
We all know how much fun it is to build a race winning car. Match the investment of $45,000 that I have in this car and you too can stand on the podium.
Or, start your season on the podium. This Rocky Mountain American Iron championship winning Camaro Z28 can be yours for $29,500. Would you rather invest $45,000 plus and spend the season sorting out your new build or stand on the podium at your first race?
Building a race car is a lot of fun, I’ve built four, but standing on the top step is so much better. Call me now to move up your race results with this fully sorted, fresh engine car.
CHASSIS
Penske custom valved 3 way remote reservoir shocks
Two sets of springs
Global West upper control arms
Factory LCA’s with new bushings and ball joints
Moog tie rod ends
Hotchkiss front and rear 3 way adjustable sway bars
With drop links and spherical bushings
Heater core block off panel
ENGINE
NEW 2013 GM LS6 Crate motor
Oil cooler, power steering cooler
Griffin radiator with custom ducting
Kooks stainless steel headers w/ custom Y pipe and muffler
Race prepped power steering pump
DRIVELINE
Custom built aluminum drive shaft
Auburn Differential
Superior axels with ARP Wheel Studs
Timkin front hubs with ARP wheel studs
3:73 and 3:90 gear set. 3:90 installed
Aluminum rear diff cover
Adjustable panhard bar
Corvette front calipers
New rear stock calipers
Blaine Fab custom front brake cooling ducts
B & M shifter
2013 rebuilt and strengthened 6 speed gear box
Raybestos brake pads all around
ELECTRICAL
Re-mapped ECU
Heavy Duty master cut-off switch
Wired for radio and data module
INTERIOR
NASA/SCCA cage with drivers side NASCAR bars plus additional strengthening
SPARCO Circuit Pro seat with slider (2010)
Fire system with 4 nozzles
Quick release suede covered MOMO steering wheel
6 point G-Force cam lock belts
Hinge mounted window net
Factory dash with custom insert for ACCUTECH gauges
EXTERIOR
Front custom ABS splitter ( you can stand on it)
Enlarged nose opening with custom ducting
VFN superlight fiberglass hood with six hood pins
GT Racing rear wing with Blaine Fab custom uprights
Four Corvette 17” X 9” racing wheels
Four CCW custom 3 piece wheels with TOYO 275/45/17 RA1
shaved to 4/32, 5 heat cycles
Front and rear tow hooks
Car was originally built by Phoenix Racing and was Mike Pettifords SCCA T-2 Championship car
Race car since new 20731 total miles
Photos at: http://www.nasarockymountain.com/nasa_forums/showthread.php?t=6176
CONTACT: Robert Ames
970-846-9070
[email protected]
I could use a new motor. Where did you source that new GM 2013 ls6?
