e36jakeo Posted December 16, 2013 Posted December 16, 2013 I bought this Black E36 M3 Sedan new in 1998 and it has never been in an accident (ever!). It evolved into a track car over time. Car has spent the majority of its life in a garage (last few years under car cover) so paint & seals are in great condition It has the S50B32 engine (3.2L Euro M3 engine, 7600 RPM redline) making 265 WHP (310 HP at the crank) - only ~30K miles on the engine Has Euro radiator for greater cooling (never overheats, even in hot weather) Has almost-new Turner Group N suspension, reinforced subframe, aluminum front control arms, and other nice suspension tweak (beautifully neutral and forgiving handling) Diffsonline 30/90 variable Ramp diff with 3.64 gears (vs. 3.23 stock) Has second fuel pump (allows minimum fuel to be run during time trials) UUC short shift kit Turner brake cooling kit Euro M3 floating rotors with PFC 01 compound front, 97s rear Sparco Pro 2000 race seat with 6 point Schroth race belts Welded in rollbar by TC Design Car is competitive in TTB (second place in 2007) and should be competitive in TTA (I have yet to run a season) Ran a 1:49 at Sears Point/Infinion/Sonoma Raceway (normal track configuration) on Hankook C51 245/40/17 tires. Ran a 2:00 at Thunderhill Here is a link to the car running a 1:51 at Sears. This is before 200 lbs was taken out of the car and 30 WHP was added with the Euro M3 3.2L Engine... Comes with trailer (no cat, so trailer-only in CA as it sits. I am located in the Bay Area on the peninsula - let me know if you are interested in taking a look. Serious buyers - may be able to set up test drive on track. Contact Jake at 415-385-6444 if interested. I can't figure out how to attach photos, so I would be happy to email you photos if you are interested. Quote
