1995 MUSTANG GT AI/AIX RACE CAR
rtunney
1995 Mustang GT
Engine and Drivetrain:
Freshly built Keith Craft 306 ci balanced and blueprinted short block, full specs upon request
AFR 164 aluminum heads, trick flow RPM II intake w 75 mm billet throttle body.
Canton road race oil pan, MSD box, high voltage MSD coil, cap and rotor.
KRC power steering pump and cooler
Quartermaster 7.5 inch triple disk clutch with flex plate style flywheel Tremec TKO 600 heavy duty road race transmission .82 fifth
gear ratio Custom small diameter steel driveshaft.
Ford 8.8 diff w/ Torsen T2 limited slip, 3.90 gear ratio, custom cambered axle tubes
Suspension, brakes, wheels and tires:
Griggs racing Short Long Arm, Griggs Racing K-member Griggs Racing
extreme duty torque arm, Griggs Racing watts linkage rear with adjustable roll center.
Custom extended length rear lower control arms, Koni aluminum body 2
way adjustable rebuildable shocks. Griggs Racing calipers with aluminum hat rotors 13.5 front 12 inch rear,
Enkie RPF1 17.5 x9.5, 17.5 lbs each. Toyo 275 x17 RA1 (Spec) tires.
Body, interior, cage, seats:
Tiger Racing carbon fiber hood (8lbs), carbon fiber aero front fenders (3lbs each) carbon fiber nose (19 lbs) carbon fiber adjustable
front splitter, G-Stream carbon fiber adjustable rear wing. Full cage exceeds nasa requirements with nascar style driver protection.
Full length subframe connectors including inside rails, rear mounted
battery box with cool shirt, helmet air system. Carbon fiber dash with center mounted tachometer, Sparco Evo II seats custom clutch/brake/gas pedal for heel/toeing.
Custom lexan side,quarter and rear window, stock glass windshield. Flared rear quarter panels to cover wide tires. Custom corner weight
system, car weight 2950 lbs w/o driver.
Dyno'd at Sneeds Speed Shop in Winston Salem NC. 336-923-2044
324HP
344TQ
Dyno sheet available upon request.
Spare matching Sparco EVO 2 seat included.
Car cover included
New NASA approved Harness for Drivers side.
2010 VIR lap record 2:08.7 on Toyo tires.
Several podium finishes, poles, this car is fast, adjustable and driver friendly.
A lot of car for $19,000
336-689-7501
See pictures below
http://s449.photobucket.com/user/SlideitSidewaysRacing/library/?sort=2&page=1
Note that Splitter is not on car in the photos.
