bmwjoon Posted January 10, 2014 Share Posted January 10, 2014 I'm posting in the ST/SU area since I think more of you guys have something like this on your car. I'm looking for a swaybar piece that accepts the splines from the bar and also a blade adjuster. Commonly the blade adjuster end is welded to the bar but I'm looking for a machined piece. Long story short I want to put blades on both ends of the bar and I can't get the bar out unless I have something like this. Thanks in advance ! Quote Link to comment Share on other sites More sharing options...
icemang17 Posted January 12, 2014 Share Posted January 12, 2014 Do you mean these http://www.1speedway.com/Swaybar_Arms.htm Quote Link to comment Share on other sites More sharing options...
Shortcutsleeping Posted January 15, 2014 Share Posted January 15, 2014 No idea why you'd want blades on BOTH ends of the sway bar....unless you just like spending money. But regardless, I think this is what you are looking for. http://www.hrpworld.com/store/default/chassis-components/swaybars-components-cockpit-adjustable.html Costas cars and such... Quote Link to comment Share on other sites More sharing options...
bmwjoon Posted January 17, 2014 Author Share Posted January 17, 2014 Thanks for the help. Genesis makes the blades and a weld on bearing holder but nothing that you can take off. I suppose I could weld the barrel onto something. If you have to know why I need 2 blades it's to have more resolution as the torsion bar itself is very, very short because it's actually inside the car. Look at the swaybar of like a DP or even a formular car. Often times there is no bar at all. Quote Link to comment Share on other sites More sharing options...
