F/S: BMW E36 M3 Race Car- GTS3 - #54 Hi Speed Motorsports
lserva
Race ready e36 M3 - NASA and SCCA logbooks. Car is located at Hi Speed Motorsports in Milford, CT and it is in race ready condition. 4 sets of wheels (see below): $21,500.00
Engine:
S52B32 3.2-liter Inline-6 E36 M3 Engine
Refreshed Cylinder Head
Rebuilt VANOS System
Custom Camshafts
Custom Intake System
EPIC ECU Software
M50 Intake Manifold Conversion
Evosport Pulley System
European-Spec Exhaust Headers
VAC Baffled Oil Pan
Dual-Fuel Pump Setup
Custom Solid Motor Mounts
Custom Side-Exit Exhaust System
Custom Wiring Harness
Braille Lightweight Battery
Transmission:
5-Speed Manual Transmission
AKG Motorsport Shifter
Quartermaster Twin-Plate 5.25” Racing Clutch w/Floating Release Bearing
3.73 Limited-Slip Differential
Custom Solid Transmission Mounts
Suspension:
MOTON Clubsport (14-clicks) 2-Way Adjustable Coilover Suspension System
Ground Control Race Camber Plates
Ground Control Racing Swaybars
Ground Control Rear Control Arms
Sean Love Roll Correction center
Custom Steering Column (Fully-Adjustable)
AKG Motorsport Front Control Arm Rear Brackets
AKG Motorsport Rear Shock Mounts
E36 M3 Steering Rack
Brakes:
E36 M3 Front Calipers (ZERO knock-back!)
E36 M3 Rear Calipers
HAWK HT14 / HT10 Brake Pads (90%+ Pad Left)
Wheels/Tires: (4 Sets)
(2 Sets) APEX 17” x 9.0” w/BFG R1s 245/40/17 Tires
(2 Sets) ASA GT5 18” x 9.0” w/Hoosier R6 255/35/18 Tires
Exterior:
Custom Front Splitter & Rear Wing
Custom Lexan Windows
New Glass Windshield (New this season)
Safety/Interior:
Full Custom Rollcage
Rollcage Extends to Front Shock Tower
Emergency Power Cutoff Switch
Kirkey Race Seat (Less Than 1 Year Old)
G-Force Pro Series Harnesses
Sparco Steering Wheel w/Quick Release
RacePak Data System
switch panel + cluster insert
Time Sheets:
Lime Rock Park: :58
NJMP Lightning: 1:12
NJMP Thunderbolt: 1:27
Watkins Glen: 2:08
Ready to run in NASA GTS2/3!
2440 lbs. w/1/4 tank of fuel (No Driver)
pictures: http://forums.bimmerforums.com/forum/showthread.php?2073454-FS-E36-M3-RACE-CAR-logbooks-for-NASA-and-SCCA-Race-ready!
  • 1 month later...
