SOLD! Spec E30 Racecar 1989 BMW 325
PDS
Sorted and solid Spec E30 build. 4 Door Rust free chassis. 4 Door gives much easier access as well as additional storage while trailering
Only six races old. Current NASA log book.
Car easily runs with front pack - no excuses.
The car has the following:
Refreshed Engine - New Head
156HP 154TQ Dyno'd after last race (November) Right in the sweet spot for Spec E30 rules!
Professional Cage by Berg Racing
Ground Control Spec E30 Camber Plates
UUC Double shear short shifter with Jaffster knob - shifts fantastic
New rotors & PFC 06 pads
Mounted rains 205/50/15 never used
IJ Crank Scraper
Racequip FIA belts
Fire system with internal & external pulls
All new control arms (6 races old)
AKG solid bushings throughout
Corbeau passenger seat with mount & belts
Complete radio system with hard case available.
Hard wired transponder
Sparco strut tower bar
H&R Wheel Spacers
Wheel Studs
Rebuilt Calipers & Braided Lines
Brake ducting with proper backing plates
Rebuilt head with new cam & all new valves, springs
Rebuilt bottom end with 2 hrs total
Oil Press/Water Temp/Oil Temp Gauges
Elec Cooling Fan
Tires have 7 heat cycles - good for one more full weekend
Spares
Oil Pan with baffle
starter
pressure plate
clutch
oil cooler
$11,500
Motivated seller - Reasonable offers entertained
Trailer Available.
2011 Dively Open Deck
21 ft total length
4 wheel electric brakes
LED lights
Only weighs 1451 lbs
Composite tool box mounted on front
Tows perfectly
Can tow Spec e30 with small SUV - rated at 4500 lbs towing capacity or greater.
True turn key outfit.
Package Price Available
Email me for pictures [email protected]
  • 3 weeks later...
