esr Posted January 25, 2014 Share Posted January 25, 2014 Would like to know if some of you are running w/o it and what are you running instead. Thanks Quote Link to comment Share on other sites More sharing options...
laze1 Posted January 25, 2014 Share Posted January 25, 2014 Clark Crawford is doing the ABS removal right now...details to follow. Quote Link to comment Share on other sites More sharing options...
FastNotFurious Posted January 26, 2014 Share Posted January 26, 2014 Would like to know if some of you are running w/o it and what are you running instead.Thanks I know someone who removed last year and went with adjustable (under the hood) boasting valve (as per rules) set at about 70/30. I've had trouble intermittently with my ABS cutting out. Which also changes the biasing in a pretty dramatic fashion - not in a good way. Not fun in the middle of track session . Though my passenger seemed to enjoy it Quote Link to comment Share on other sites More sharing options...
esr Posted January 26, 2014 Author Share Posted January 26, 2014 Had the same experience, don't want the added stress! Do you have contact info for that guy? quote="FastNotFurious"] Would like to know if some of you are running w/o it and what are you running instead.Thanks I know someone who removed last year and went with adjustable (under the hood) boasting valve (as per rules) set at about 70/30. I've had trouble intermittently with my ABS cutting out. Which also changes the biasing in a pretty dramatic fashion - not in a good way. Not fun in the middle of track session . Though my passenger seemed to enjoy it Quote Link to comment Share on other sites More sharing options...
FastNotFurious Posted January 26, 2014 Share Posted January 26, 2014 Had the same experience, don't want the added stress!Do you have contact info for that guy? quote="FastNotFurious"] Would like to know if some of you are running w/o it and what are you running instead.Thanks I know someone who removed last year and went with adjustable (under the hood) boasting valve (as per rules) set at about 70/30. I've had trouble intermittently with my ABS cutting out. Which also changes the biasing in a pretty dramatic fashion - not in a good way. Not fun in the middle of track session . Though my passenger seemed to enjoy it Contact ldstang on this forum.... Quote Link to comment Share on other sites More sharing options...
laze1 Posted January 26, 2014 Share Posted January 26, 2014 talk to Clark as well...he is completing the work this weekend... Quote Link to comment Share on other sites More sharing options...
esr Posted January 26, 2014 Author Share Posted January 26, 2014 thanks, do you have contact info for Clark? talk to Clark as well...he is completing the work this weekend... Quote Link to comment Share on other sites More sharing options...
Members Brian L. Posted January 27, 2014 Members Share Posted January 27, 2014 I removed the system for a customer. A couple of T fittings, some adapters, and you can pull out the unit entirely. Brakes are great without the ABS! Quote Link to comment Share on other sites More sharing options...
laze1 Posted January 28, 2014 Share Posted January 28, 2014 All, I am working with Clark to make a full parts list and a "how too" doc with pics. We should have that together in a couple of weeks. As other have said, this isn't all that complex of a task. However it is a PIA to get all the correct parts together that will make it 100% robust and no leaks/no major installation hassles. more to follow...version Zero is complete, thinking about Version 1 now... Quote Link to comment Share on other sites More sharing options...
laze1 Posted January 28, 2014 Share Posted January 28, 2014 we are looking at the 2nd fuel pump mod as well... Quote Link to comment Share on other sites More sharing options...
esr Posted February 5, 2014 Author Share Posted February 5, 2014 did you install any type of proportion valve? quote="B Esquire"]I removed the system for a customer. A couple of T fittings, some adapters, and you can pull out the unit entirely. Brakes are great without the ABS! Quote Link to comment Share on other sites More sharing options...
Members Brian L. Posted February 7, 2014 Members Share Posted February 7, 2014 did you install any type of proportion valve? quote="B Esquire"]I removed the system for a customer. A couple of T fittings, some adapters, and you can pull out the unit entirely. Brakes are great without the ABS! Yes I installed a screw type proportioning valve under the hood where the ABS pump was. Quote Link to comment Share on other sites More sharing options...
esr Posted March 5, 2014 Author Share Posted March 5, 2014 Any word on that set up, for abs removal? All, I am working with Clark to make a full parts list and a "how too" doc with pics. We should have that together in a couple of weeks. As other have said, this isn't all that complex of a task. However it is a PIA to get all the correct parts together that will make it 100% robust and no leaks/no major installation hassles. more to follow...version Zero is complete, thinking about Version 1 now... Quote Link to comment Share on other sites More sharing options...
Blurvision Posted March 12, 2014 Share Posted March 12, 2014 Any more details on ABS removal? Are you using a prop valve on the rears? Quote Link to comment Share on other sites More sharing options...
laze1 Posted March 12, 2014 Share Posted March 12, 2014 I still don't have a write-up or pics... however the entire ABS Assembly was removed, braided hoses used throughout, Tee-blocks, and a proportion valve used to manage the rear brake bias. Worked great, but have some initial fluid seepage due to the incompatability of the various brands of fittings used. But after some heat cycles and snugging the fitting…everything worked great. you don’t want to over tighten them for sure… The driver report a “Good -Hard Pedal”…like in the old days before ABS Quote Link to comment Share on other sites More sharing options...
Blurvision Posted March 13, 2014 Share Posted March 13, 2014 Thank you for the feedback, curious how much rear bias was taken away using the prop valve. How did the lap times look? Quote Link to comment Share on other sites More sharing options...
pueblopete Posted April 10, 2014 Share Posted April 10, 2014 I had a question on this. I've looked up the hydraulic circuit diagram and the primary side of the master cylinder goes to the Front Left and Rear Right and the secondary side goes to the Rear Left and Front Right. How do you end up plumbing this with a proportional valve. Is there a reason they alternated the primary and secondary sides? Thanks for any info! Pete Quote Link to comment Share on other sites More sharing options...
esr Posted April 11, 2014 Author Share Posted April 11, 2014 Remember some shop teacher saying it was a safety thing so the car would still brake straight. Is there a difference between the circuits? I would assume no! quote="pueblopete"]I had a question on this. I've looked up the hydraulic circuit diagram and the primary side of the master cylinder goes to the Front Left and Rear Right and the secondary side goes to the Rear Left and Front Right. How do you end up plumbing this with a proportional valve. Is there a reason they alternated the primary and secondary sides? Thanks for any info! Pete Quote Link to comment Share on other sites More sharing options...
pueblopete Posted April 14, 2014 Share Posted April 14, 2014 Remember some shop teacher saying it was a safety thing so the car would still brake straight.Is there a difference between the circuits? I would assume no! quote="pueblopete"]I had a question on this. I've looked up the hydraulic circuit diagram and the primary side of the master cylinder goes to the Front Left and Rear Right and the secondary side goes to the Rear Left and Front Right. How do you end up plumbing this with a proportional valve. Is there a reason they alternated the primary and secondary sides? Thanks for any info! Pete No, there isn't. A couple others suggest the same as you that it was there for a safety thing and can be switched. Thanks! Quote Link to comment Share on other sites More sharing options...
