vcavallaro Posted August 7, 2005 Share Posted August 7, 2005 If a recommended toe setting is said to be 0.5° toe-out, does that mean a total of 1° when left and right are combined? Or is that a total amount? I would take it as a single side measurement since other measurements are given on a single side basis. I'm setting the toe on my '98 Cobra and have seen a recommended 0.5° toe-out for racing. I currently have 0.4° at each side, for a total of 0.8°. I recently ran at Gingerman and had a problem with the right front wearing excessively on the inside shoulder. At the time, I thought it was a camber problem and made an adjustment at the track that helped a lot. But upon further research, I am inclined to believe it was a toe problem. I ran Road Atlanta with the same settings as my initial settings at Gingerman without any problem at all. I was running R3S03s and had a camber setting of -2.5° and a caster of 6.5°. Gingerman involves a whole lot of time in right hand turns, but Road Atlanta is a clockwise track also. I hope I have given enough information, but let me know if anything else is needed to accurately diagnose. Any help would be greatly appreciated. Quote Link to comment Share on other sites More sharing options...
vcavallaro Posted August 10, 2005 Author Share Posted August 10, 2005 Bueller..... Bueller..... ????? Come on guys. Quote Link to comment Share on other sites More sharing options...
davidfarmer Posted August 15, 2005 Share Posted August 15, 2005 I usually would assume .5 deg means .5 deg total. 1/2 deg is nearly 3/16". That sounds like a lot of toe out to me. I usually run about 1/16 total toe out in the front. You create a lot of rolling resistance (bearing & tire wear) if you run very much. Dave Quote Link to comment Share on other sites More sharing options...
vcavallaro Posted August 15, 2005 Author Share Posted August 15, 2005 (edited) Thanks a lot for the response Dave. That's what I suspected. But I have to take this a little further. Unless there is a standard for the distance between front and rear measurements, giving settings in terms of inches doesn't make a lot of sense. It would vary based on the size of the toe plates you use. There may be a standard that I'm not aware of though. I'm not using a professional set of plates and maybe they're all made so that the front and rear measurements are taken at a set distance apart. Thanks again for the input and I enjoyed the hell out of watching you this weekend. Good luck with your racing. Edited August 16, 2005 by Guest Quote Link to comment Share on other sites More sharing options...
V8cobra99 Posted August 15, 2005 Share Posted August 15, 2005 1/8th toe out is about max in most cases. Quote Link to comment Share on other sites More sharing options...
davidfarmer Posted August 16, 2005 Share Posted August 16, 2005 I always work on the same car, and inches are the way I do it. I make my measurements at the rim, so the spread is 18". If you want to give us your diameters (measured at the tire edge??), I'll be happy to re-analyze it. As a mechanical engineer, I live for doing Trig and Geometry btw, here is a diy alignment sheet I did for the Corvette Forum a few years ago. It is very repeatable and uses only a tape measure and straight edge. Toe and Camber only, but I can explain diy castor if you need my method. For a track only Vette, castor isn't really a very usefull measurement. http://www.metricchemical.com/align.PDF Quote Link to comment Share on other sites More sharing options...
vcavallaro Posted August 17, 2005 Author Share Posted August 17, 2005 Thanks for the great info guys. I know I have waaaaay too much. I guess I'll reset it this weekend to be 1/16" @ 17". I believe that works out to be about 0.2° and should be conservative based on what's been posted here. Quote Link to comment Share on other sites More sharing options...
davidfarmer Posted August 17, 2005 Share Posted August 17, 2005 yes, that works out to about 0.2 deg, and sounds perfect! Quote Link to comment Share on other sites More sharing options...
