enclosed trailer towing?
aaronsti
so this year i'm going to start towing my car in an enclosed 20 foot trailer. the tow vehichle is a 2007 gmc Yukon denali. do I need to get a weight distribution hitch and swaybars or not? I already have a brake controller installed. thanks
What is the GCVW of your setup? Also, you will want to know what your tongue weight is. You should also get a weighted tag for your tow vehicle that is equal to the GCVW. A weight distribution hitch will add about 50-60 pounds to the rear of your truck. I know that this does not answer your questions, but these things will help you figure out what you need to do. With my rig now I use air helper springs in place of a weight distribution hitch. I have never needed an anti-sway bar, but I tow an open trailer. Hope some of this helps you.
I tow a 20' V-nose ATC with my Titan with only a weight carrying hitch. I have Firestone aribags to level it out. I can't use my Equalizer hitch with the V-nose setup. Previously I towed my 18' steel open trailer using an Equalizer hitch (overkill) from when I had a smaller truck. Towing my father's steel 24' enclosed I use the bags and a 10k equalizer hitch.
So the answer depends on the gross weight of what you'll be towing. A Yukon is a short wheelbase and would probably benefit a bunch from sway control. I think those also have factor self-leveling air bags. Not sure how those work for towing, but I know that if I had to choose one (bags or sway control distribution hitch) I'd pick bags.
Manual should tell you. Or there is actually a label right at the hitch. I used to tow with a 2008 Denali and I am pretty sure it said over 5000 lbs use a weight distribution.
Also be advised that the Denali air system will cost you thousands when it fails. I had multiple failures and repaired the system. 11 months later it failed again, luckily covered under the warranty. A week laterit was gone for a truck.
I have owned and tow all kinds of rigs, currently have 3 boats, 4 jetskis, and a toy-hauler for the racecar.
Denali's have air bags but they are made for leveling the truck, not heavy towing. (wife has a 2011 Denali XL)
Some states require weighted tags, others never check (In VA I towed a 15K boat for years without ever getting checked)
So, have you towed much in the past and comfortable doing so? What is the weight of your car.......and weight of the trailer/gear? You will need to load the car to effect tongue weight for the amount of weight you want on the truck.....can you measure it? with the truck off (because of the airbags) I'd like to see a 1.5-2 inch squat.
Its not a problem towing with your Denali with 600 lbs tongue weight with out the weight distributing hitch for local events but if your going to drive long distance events your air bags could be the weak link if your in the middle of no where, plus I feel you maybe maxing out your towing capacity of 8000 lbs not knowing what your car weigh in at with spares.
From driving to Lincoln Neb and Topeka Kansas for the last 12 years a real truck is a real peace of mine.
Ben
thank you everybody. I have a lot of towing experience with a boat. but its a light combo at about 2700lbs. i'm not sure what my gcvw is. i'll look into that. I don't really have a way to measure tongue weight. the trailer weighs 3000, the car weighs 3200. I figure i'll probably be adding about 300 lbs of random things and back ups. so that puts me around 6500. it does have the factory air suspension. ill look into replacing that.
  • 1 month later...
You've probably got this figured out by now, but what I found is the following;
Dead Weight Hitch - Max Trailer Wt. 5000 lbs
Dead Weight Hitch - Max Tongue Wt. 500 lbs
Wt Distributing Hitch - Max Trailer Wt. 7900 lbs
Wt Distributing Hitch - Max Tongue Wt. 1185 lbs
Maximum Payload Capacity 1704.00 lbs
Gross Combined Wt Rating 14000 lbs
Gross Axle Weight Rating 7650.00 lbs
Curb Weight 5396.00 lbs
Gross Vehicle Weight Rating 7100.00 lbs
From etrailer.com
When Is Weight Distribution Needed?
You would likely benefit from a weight-distribution system if:
Your trailer weight (GTW) is more than 50 percent of your vehicle's weight (GVWR)
The rear of your tow vehicle sags when the trailer is hooked up
You experience trailer sway
Your tow vehicle headlights point upward
You find it difficult to steer or stop your rig
You want to tow to the highest capacity allowed by your vehicle's trailer hitch setup
I have a Ford Expedition with tow package etc, and use a 10,000lb rated WD to haul a 2500lb trailer and a 3600lb car.
sway bars are obnoxious and their effectiveness is negligible... proper loading and hitch height help/hurt much more!
Get the distributing hitch.
You need the whole deal. Your setup is likely pushing the max tow limits even with a WD hitch, on a relatively short wheelbase vehicle. You should get the tongue weights correct through car positioning, *and* get a sway control device. You need all the help you can get.
like a bigger/badder truck - I wouldn't do an enclosed with what you're pulling with. But if you are, belt & suspenders yourself as best you can AND take it really easy getting to/from the track.
I've done this stuff for 10+ years and never *needed* an enclosed trailer. YMMV though.
