Price Reduced 98' SVT Mustang Cobra $19,500.00
Yellow Snake
For Sale 98’ SVT Mustang Cobra $19,500.00 Sioux Falls, SD
JUST COMPLETED THE CAGE PROJECT AND GOT THE CAR OUT OF SHOP AND LIFE HAS GOTTEN IN THE WAY OF COMPLETING SO I AM PUTTING IT UP FOR SALE.
FOR SALE 98’ SVT MUSTANG COBRA $22,500.00 A.I. – ST3 - TT3 – T3 OPEN TRACK CAR
25,538 original miles on car. All build documentation provided. 301.20 RWHP 294.58 RWTQ on Dynojet dyno 6/20/12. Over $58,000.00 invested. 2012 N.A.S.A. Central Division TTA Champion.
ENGINE AND DRIVETRAIN
4.6 L Teskid Block
Canton oiling system pan, cooler, thermostat, remote oil filter w/Fragola S.S. lines & fittings (Redline Oil)
Accusump 3 quart w/electric solenoid
Modified BBK 62mm throttle body w/matched intake
Walbro 255 LPH fuel pump
BBK adjustable fuel pressure regulator
WMS C.A.I.
Pro-M 87 mm MAF
BBK LT ceramic coated headers w/stage 8 bolts
BBK off road H pipe ceramic coated
Flowmaster ceramic coated mufflers
MSD DIS-4 w/MSD coils and Thunder Volt 10mm wires
Braille light weight battery
Taylor 4 pole master disconnect switch (Purchased 8/15/13)
Auto-Rod Controls master switch panel 8 positions (Purchased 8/15/13)
Custom crankcase breather system
LFP/Fluiddyne 4 core aluminum radiator
Meziere electric water pump
SCT X3 Tuner
Steeda billet clutch quadrant and firewall adjuster
Innovators West underdrive crankshaft dampener
Ford racing aluminum driveshaft
HPM driveshaft safety hoop
Torsen T-2R limited slip diff. 31 spline
Moser 31 spline axles w/ARP studs
Moser aluminum rearend cover
Ford racing 3.73 and 4.30 gear sets
Pro- 5.0 shifter
Ford Racing A/C delete
SUSPENSION AND CHASSIS
Complete custom road racing roll cage with foot well protection (Completed 2/1/14)
Custom 1 ¾”D.O.M. front & rear bumpers (Completed 2/1/14)
Custom upper steering shaft w/removable Momo steering wheel (Completed 2/1/14)
Flaming River lower solid steering shaft
ASP solid motor mounts
ADDCO front sway bar w/Steeda aluminum mounts
Kenny Brown matrix subframe connectors
Complete Maximum Motorsports track package (Every piece Maximum Motorsports has for the SN95 is on car)
Koni double adjustable coilovers
BRAKES
Front Brembo 4 piston w/Hawk DTC 70 pads
Rear stock w/Hawk DTC 60 pads
Baer 2 piece rotors front & rear
Spare Brembo front & stock rear rotors
Russell S.S. brake lines front & rear
Quantum Motorsports brake cooling ducts
WHEELS AND TIRES
4 18X9.5 2000 Cobra R wheels and 4 18X9 & 18X10 Ford GT wheels w/295 & 305 Toyo R888’
EXTERIOR AND INTERIOR
Complete set of Pro Glass molded Lexan windows still has protective coating (Purchased 12/15/14)
Cervinis 2000 Cobra R front bumper cover (Purchased 8/15/13)
Ford Racing 95’ Cobra R hood w/billet hood pins
Cobra Sebring Pro Kevlar w/side alloy mounts FIA certified (Purchased 11/15/13)
Simpson 6 point FIA harnesses (Purchased 1/15/14)
G-Force window net
Momo steering wheel
Longacre 14” convex mirror
SRP racing pedals
Autometer Phantom gauges (Some N.I.B. purchased 12/15/14)
CONTACT JERRY AT [email protected] or 605-351-7110
