Bnjmn Posted March 4, 2014 Share Posted March 4, 2014 FS is a set of (4) Goodyear G614 trailer tires. 3750lbs load capacity. Wheels and tires are used, tires are in good shape, wheels have some rust but are functionally fine. Wheels are 16 x 6.5", 8 lug, as are typically found on 7000 or 7200lb axles. The tires are $370/each new at Walmart. Here are the specs: Tire Size *LT235/85R16 Load Range G Apprvd. Rim Widths -- 6.5" Overall Width - 9.50" Outside Diameter - 30.7" Max Load at Infla. (PSI) (Single Tire Config) - 3750@110psi Rated to 75mph $500, located in Berlin, NJ PM for pics or Q's. Quote Link to comment Share on other sites More sharing options...
