esr Posted March 8, 2014 Share Posted March 8, 2014 What are the better set ups? Pros and cons. Thanks Quote Link to comment Share on other sites More sharing options...
Members Brian L. Posted March 8, 2014 Members Share Posted March 8, 2014 Better than what? Quote Link to comment Share on other sites More sharing options...
esr Posted March 8, 2014 Author Share Posted March 8, 2014 Not sure, I am sitting w/o exhaust. Sold what came with the car already! Better than what? Quote Link to comment Share on other sites More sharing options...
esr Posted April 9, 2014 Author Share Posted April 9, 2014 Anyone willing to share info on different exhaust systems available. Pros and cons. Thanks Quote Link to comment Share on other sites More sharing options...
TXOL Posted April 10, 2014 Share Posted April 10, 2014 From my research there are almost as many opinions out there as exhaust systems. The consensus is that a single pipe system will make the most power with a stock engine. The cat back systems don't add much horsepower (generally under 10) so honestly weight of the system can be more of a factor than expected HP gains. Getting the cat out the of the picture is probably the biggest factor in increasing HP. There are some pretty good posts out on the Z forums that can give you some ideas. Quote Link to comment Share on other sites More sharing options...
esr Posted April 10, 2014 Author Share Posted April 10, 2014 Thanks, Do you know who makes a good quality single? Most of what I found is doble. Thanks quote="TXOL"]From my research there are almost as many opinions out there as exhaust systems. The consensus is that a single pipe system will make the most power with a stock engine. The cat back systems don't add much horsepower (generally under 10) so honestly weight of the system can be more of a factor than expected HP gains. Getting the cat out the of the picture is probably the biggest factor in increasing HP. There are some pretty good posts out on the Z forums that can give you some ideas. Quote Link to comment Share on other sites More sharing options...
robsilver350 Posted April 13, 2014 Share Posted April 13, 2014 (edited) Along the lines of OP's question, is it worth dropping the exhaust heat shielding? According to Rule 12.4 "c) Stock exhaust heat shielding may be removed." Edited April 13, 2014 by Guest Quote Link to comment Share on other sites More sharing options...
esr Posted April 13, 2014 Author Share Posted April 13, 2014 If you are talking about the manifolds, I put mine back because I got no reply about it. But I was also wondering of any other around the transmission if there was one. I can't remember. What exhaust do you have? It's it a single and who makes it? Along the lines of OP's question, is it worth dropping the exhaust heat shielding? Quote Link to comment Share on other sites More sharing options...
robsilver350 Posted April 13, 2014 Share Posted April 13, 2014 Still stock right now, but I may just go with test pipes into NISMO cat-back setup, but I'm curious to hear what other members run. Quote Link to comment Share on other sites More sharing options...
laze1 Posted April 13, 2014 Share Posted April 13, 2014 Using a single pipe from the y-pipe back gives you room for the diff cooler that I highly recommend...and is lighter and will likely make a little more power than the stock setup. Quote Link to comment Share on other sites More sharing options...
