Dyno results at RA Pot-o-Gold questions?
RJ's325ITS
RJ's325ITS
So I've heard that a lot of people got their feelings hurt with their dyno results! something alone the lines of dynoing 20whp to 30whp less than expected.
Can any one elaborate on this please.
Did any one of you saw a big discrepancy on your dyno results?
BTW, any one knows the name of the company that operates said dyno? or where they are located? I would like to try to dyno my car with them (I want to make sure I'm compliant to my series rules).
thanks in advanced!!!
Link to post
Interesting, considering we had some guys dyno within .5hp of class limits.
If it was reading that low, then I need to add some power to my car to keep up!
Link to post
Firebird Man
We made 4 pulls and never got any data at all. Not a very good system IMO.
It would shut itself off when I nailed it, probably to save itself from all that Pontiac Tq.
I'd go find someone with a better unit or an inground system.
Link to post
DriverGT5
From what I heard we may not have the same dyno back again. I think a lot of people had issues with errant readings among other things. I wouldn't run out to dyno tune the car with them if you expect that same dyno to be at the rest of the events.
Link to post
DriverGT5
What wires are you running? I have heard people running high dollar racing wires can have problems because they cut so much noise out the dyno can't pick up RPMS.
Link to post
Firebird Man
We thought about the wires and MSD system, so after 2 runs we switched wires, after 3 runs we took the lead off the plug wires, he said we should still have got HP straight off the drum with the plug lead off, but nothing. Engine was too hot after that to try any more ideas.
Might have been the flux capacitor causing it?
But I've run it on several in ground dyno's without issues.
Link to post
Pretty sure my dyno was low- we dynoed 5 944-Spec cars, all except mine were from 128-138 hp.
My 2 runs were at 94.1 and 105.5 hp.
I was hanging with the other spec cars fine in the straights so I can't imagine my runs were accurate.
Link to post
RJ's325ITS
Begs the question if anyone was DQ'd for their dyno result.....
So I’m proactively trying to prevent that from happening to me!
The place that I dyno tune my car for the last 2 years was reading about 8whp higher than the NASA approved dyno, it took me a few tries to find the delta and compensating for it!
Link to post
Sterling Doc
128-138 is exacty the normal range for tired vs. top-tier Spec motors, so that seem OK, but at your numbers are highly suspect - it would have to be running obviously poorly, and you'd get stuck 1/2 up the T1 hill at Road Atlanta...
Link to post
I dyno'ed 371 back to back on a stock C5 Z06. I thought it was a tiny bit high?
Sounds right for an 03-04 Z06. My car was just under that stock and I know of one other that was just higher than that when stock (stock with a K&N for both).
Link to post
Make that 3. I think I started out just under that and ended up at 381 with a tune. (stock with a K&N).
Link to post
  • Members
The ThunderChicken was a little low (115 vs 119) but the FireEngine was just what we thought it should be (132).
We are looking into other options for a dyno, Will Baumeister is researching buying one or building one - so stay tuned...
Link to post
Need to put that thing in a museum.
Link to post
Red Tornado
Differences in dynojet numbers do occur but it is almost always based on roller size of that dynojet specifically.
At car shows when they want max numbers they use smaller. We just had that at the Trans am event. Everyone was 5-8 percent high.
My sealed boss motor has never made less than 396 rwhp or more than 407 based on many years of nationals events etc. at Sebring on the smaller dyno jet roller model it made 430rwhp.
That's why top speed readings at the end of the longest straight is a good benchmark double check.
Link to post
Help put the word out. I'd love to hear from the NCM.
Link to post
I hear they have a lot more room now since they've added a new basement.
Link to post
  • Members
7 SpecE30's dynoed at RA. Two of those cars had also dynoed at Balanced Performance in Atlanta 2 months prior.
5 cars "seemed" to be ~5hp low. Mine included.
1 car got 5hp less at RA vs. Balanced Performance. As a result we were thinking this was pretty conclusive that the RA dyno was 5hp low.
Then the last car got 2-3hp higher at RA then BP and that kind of blew out our simple theory.
Link to post
Interesting... The inconsistency is not confidence inspiring :/
NE guy here keeping an eye on this since we will be down for Nationals...
Link to post
  • Members
I doubt very seriously that the guy we had at this event will be who we have at the National event...
Ed
Link to post
Ed
ditto. wouldn't nationals have to use a dynojet since that's what the rules state? also if everyone dynes 5whp high, you think they will dq a whole field?
Link to post
