hyunjong Posted May 11, 2014 Share Posted May 11, 2014 Hello everyone, I was hoping to get some clarification with a rule. Section 8.3 reads: "Forced induction vehicles that have been classed or re-classed by the National TT Director based on Dyno testing are exempt from this additional five (+5) point assessment." What if I dyno a Forced Induction car due to an additional ECU map, but keep the weight/power ratio within existing class limits. Can I also be exempt from the additional 5 point assessment? Thanks ahead of time. Quote Link to comment Share on other sites More sharing options...
Arca_ex Posted May 11, 2014 Share Posted May 11, 2014 Read the rule. The answer is no. You can submit for a dyno reclass though. In some cases the base class can remain the same and you will be given a maximum WHP and a minimum competition weight, then you will also not take any points for engine mods or weight reduction. Quote Link to comment Share on other sites More sharing options...
kbrew8991 Posted May 12, 2014 Share Posted May 12, 2014 (edited) The hp/weight cap limits are typically not really breached unless it's a car that has some big flaws - like a Fox Mustang that can't stop and turn. Makes up time on straights, gives it back in corners. That sort of thing. Dyno the car, ask for a reclass, see where you fall. Or take the +5 assesment that's a hold-over from where ECU reflashes used to be points mods - was +2 for NA and +7 for FI or something like that. Since it became far too difficult to police, they became a free mod but the spread between the two became that +5 automatic assesment for FI cars. Edited May 12, 2014 by Guest Quote Link to comment Share on other sites More sharing options...
SNAKBITN Posted May 12, 2014 Share Posted May 12, 2014 like a Mustang that can't stop and turn Hater...... Quote Link to comment Share on other sites More sharing options...
kbrew8991 Posted May 12, 2014 Share Posted May 12, 2014 like a Mustang that can't stop and turn Hater...... edited - got some love for the S197 - almost a properly designed chassis finally Quote Link to comment Share on other sites More sharing options...
hyunjong Posted May 13, 2014 Author Share Posted May 13, 2014 So, if I'm understanding this correctly, I can either 1) Take the 5 point penalty and reflash the ecu. HP gains are then arbitrary. 2) Get dynoed, ask for reclass, and even if I fall in the same class, I can remove the +5 assessment. Quote Link to comment Share on other sites More sharing options...
kbrew8991 Posted May 13, 2014 Share Posted May 13, 2014 That is correct mostly. With option 1 you're stuck with the +5 pts either way, but you might as well reflash the ECU since it's a free mod and may yield some good gains. With option 2 you don't take points for any power mods (which includes that +5pts for FI) but you have to stay under the whp cap you're given as part of the reclass in trade. Quote Link to comment Share on other sites More sharing options...
ILIKETODRIVE Posted May 13, 2014 Share Posted May 13, 2014 To add to option 1: WHP gains are not arbitrary in that you still have to stay within class limits for weight-to-power. Quote Link to comment Share on other sites More sharing options...
hyunjong Posted May 13, 2014 Author Share Posted May 13, 2014 Thanks for the responses. They have been helpful. In conclusion: It seems, according to the rules, I can tune the ECU, request a dyno reclass, and if I fall within my class limits, I am then exempt from the 5 point penalty. Quote Link to comment Share on other sites More sharing options...
