Yellow Snake Posted May 17, 2014 Share Posted May 17, 2014 MUST SELL 98’ MUSTANG COBRA BEST OFFER BY 6/30/14 JUST COMPLETED PROFESSIONAL CAGE INSTALLATION 3/1/14. ALL PARTS INCLUDED FOR ASSEMBLY TO FINISH. A.I. – ST3 - TT3 – T3 OPEN TRACK CAR 25,538 original miles on car. All build documentation provided. 301.20 RWHP 294.58 RWTQ on Dynojet dyno 6/20/12. Over $58,000.00 invested. 2012 N.A.S.A. Central Division TTA Champion. ENGINE AND DRIVETRAIN 4.6 L Teskid Block Canton oiling system pan, cooler, thermostat, remote oil filter w/Fragola S.S. lines & fittings (Redline Oil) Accusump 3 quart w/electric solenoid Modified BBK 62mm throttle body w/matched intake Walbro 255 LPH fuel pump BBK adjustable fuel pressure regulator WMS C.A.I. Pro-M 87 mm MAF BBK LT ceramic coated headers w/stage 8 bolts BBK off road H pipe ceramic coated Flowmaster ceramic coated mufflers MSD DIS-4 w/MSD coils and Thunder Volt 10mm wires Braille light weight battery Taylor 4 pole master disconnect switch (Purchased 8/15/13) Auto-Rod Controls master switch panel 8 positions (Purchased 8/15/13) Custom crankcase breather system LFP/Fluiddyne 4 core aluminum radiator Meziere electric water pump SCT X3 Tuner Steeda billet clutch quadrant and firewall adjuster Innovators West underdrive crankshaft dampener Ford racing aluminum driveshaft HPM driveshaft safety hoop Torsen T-2R limited slip diff. 31 spline Moser 31 spline axles w/ARP studs Moser aluminum rearend cover Ford racing 3.73 and 4.30 gear sets Pro- 5.0 shifter Ford Racing A/C delete SUSPENSION AND CHASSIS Complete custom road racing roll cage with foot well protection (Completed 2/1/14) Custom 1 ¾”D.O.M. front & rear bumpers (Completed 2/1/14) Custom upper steering shaft w/removable Momo steering wheel (Completed 2/1/14) Flaming River lower solid steering shaft ASP solid motor mounts ADDCO front sway bar w/Steeda aluminum mounts Kenny Brown matrix subframe connectors Complete Maximum Motorsports track package (Every piece Maximum Motorsports has for the SN95 is on car) Koni double adjustable coilovers BRAKES Front Brembo 4 piston w/Hawk DTC 70 pads Rear stock w/Hawk DTC 60 pads Baer 2 piece rotors front & rear Spare Brembo front & stock rear rotors Russell S.S. brake lines front & rear Quantum Motorsports brake cooling ducts WHEELS AND TIRES 4 18X9.5 2000 Cobra R wheels and 4 18X9 & 18X10 Ford GT wheels w/295 & 305 Toyo R888’ EXTERIOR AND INTERIOR Complete set of Pro Glass molded Lexan windows still has protective coating (Purchased 12/15/14) Cervinis 2000 Cobra R front bumper cover (Purchased 8/15/13) Ford Racing 95’ Cobra R hood w/billet hood pins Cobra Sebring Pro Kevlar w/side alloy mounts FIA certified (Purchased 11/15/13) Simpson 6 point FIA harnesses (Purchased 1/15/14) G-Force window net Momo steering wheel Longacre 14” convex mirror SRP racing pedals Autometer Phantom gauges (Some N.I.B. purchased 12/15/14) CONTACT JERRY AT [email protected] or 605-351-7110 http://sd.craigslist.org/cto/4474755759.html Quote Link to comment Share on other sites More sharing options...
delta159 Posted June 3, 2014 Share Posted June 3, 2014 beautiful car! Quote Link to comment Share on other sites More sharing options...
