dp Racing Dan Posted June 5, 2014 Share Posted June 5, 2014 So I've decided I want to do a Coyote Swap into the Drift Patrol. I need the revs, and really want the reliability of the new motor. The only way I can do that is by parting out the current motor/supercharger setup. I'm selling it ALL. From the MSD, blower setup, heads, intake, headers, etc etc etc. I'll be posting up a detailed list with pictures over the next few days. Contact me for questions- please contact me directly @ dpracingdan@ gee mail dot com or you can even text me @ 650 eight three four three nyne nyne three HERES a list of the parts I'm selling and prices. All these parts have about 10-hours of run-time max on them- many of them only a couple hours. This car is used for competition only- zero street use. All parts are used but in good working order. Heads - fms-m6049z304da7?(with valves, springs, and hardware)( I had 220 valves cut down to 194s to work on regular SBF (5.0) (were from BOSS 347 crate motor) $1000 Rockers- M 6564 F351 $300 Headers- M-9430-ZM7993 (discontinued!) (shorty putting Z heads into fox w VHT ceramic paint) $250 Trick Flow Track Heat Upper and Lower Intake manifold- silver powder coat- $475 Complete Blower Setup - Paxton SL1200 w after-cooler, electric RV Water Pump, 4 gallon water cell, 04 Cobra Heat exchanger, Vortech Power cooler, Race Bracket Upgrade, Upgraded discharge Tube and Mondo BOV, Silicone couplers, T-clamps, 8-Rib Belt Setup, spare pulley, Spare 8-rib belts, couplers, tensioner pulley/brackets, (battery sized) after cooler tank, smaller electric water pump, 15' of 3/4" water plumbing etc. (this system would cost $6000 to emulate) $3000 Paxton Fuel Rails (blue annodized- never used) - $150 Alternator- 130 Amp 3G- $75 Smog Pump Delete- $50 AC Delete- $50 Mini Starter-$75 March Performance Front Mounted Power Steering Brackets- March Performance 30038 - $100 March Performance 1979-93 5.0L Ford Pulley Kits 2210 – Retail $100 - $75 60 lbs Fuel Injectors (2 hours old) – $400 MAF - $175 K&N Filter- $50 60lbs injectors and matching MAF (2 hours old) - $600 Adjustable Fuel Pressure Regulator – $75 A9P ECU -(2 hours old) $100 Throttle body and spacer - $175 Aluminum Water Pump- $50 (I have 2) EGR- $25 IAC- $30 Wires- $50 (about 4 sets- FMS, Taylor, MSD, etc) MSD Distributor- $225 Cap & Rotor – $30 MSD Coil- $30 MSD 6AL Box –$175 Trick Flow Valve Covers- Powder Coated Silver- (modified- 3/4" breathers added to each) -$75 CHICAGO Quote Link to comment Share on other sites More sharing options...
