Want2race Posted August 17, 2005 Share Posted August 17, 2005 This is the cage I am trying to replicate for Super unlimited/kit car challenge. http://www.want2race.net/lotus7/p0000568.jpg I cannot work out how I could acceptably attach the front lower hoop to the car. At that point in the car there is nothing to attach it to. Can anyone help explain or hopefully provide pictures as to how I could attach this piece? Many thanks ~Jonathan Quote Link to comment Share on other sites More sharing options...
davidfarmer Posted August 17, 2005 Share Posted August 17, 2005 does the car have a frame (tube or otherwise), or is it a unibody/tub car? Somehow, you are going to either have to weld/bold standoffs to the side of the chassis, or curve the bottom of the tubing inward so that it attaches to the side of the frame. Quote Link to comment Share on other sites More sharing options...
Want2race Posted August 17, 2005 Author Share Posted August 17, 2005 does the car have a frame (tube or otherwise), or is it a unibody/tub car? Somehow, you are going to either have to weld/bold standoffs to the side of the chassis, or curve the bottom of the tubing inward so that it attaches to the side of the frame. its a tube frame car. I really liked the idea of a bolt that attached but I dont know if it would be legal. http://www.want2race.net/lotus7/caterham.jpg The turn inwards idea does not appeal to me at all. I dont like the way it needs 6" away from the car. Do you think that bolt type mounting would be legal ? Quote Link to comment Share on other sites More sharing options...
davidfarmer Posted August 18, 2005 Share Posted August 18, 2005 I dont' think I would go for the single bolt mount. I think you could have a bolt-joint, but it would need to be of some size and thickness, and have at least 4 bolts. Possibly weld a 90 deg turn-out on the sides (instead of a bend). If you want it removable, you can use 2" tubing to make slip joints, although many clubs are getting away from bolt in cages. Is this car already built, or is this a future project? **note: unlike the photo you listed, in this shot, the overlap of the tubing is doing most of the work. The bolt is only holding it together. Quote Link to comment Share on other sites More sharing options...
Want2race Posted August 18, 2005 Author Share Posted August 18, 2005 The car is mostly built but needs the cage before it can be sent off for galvanising. http://www.want2race.net/lotus7 I think the way you have shown would work but dont know if I like the way it looks since its going on the outside of the car. Quote Link to comment Share on other sites More sharing options...
lello7 Posted August 19, 2005 Share Posted August 19, 2005 Here is a link to some pictures of how the cage in your picture was attached to a Caterham. http://www.teambirkinsport.com/gallery/album27 I checked out your site and your car looks like it will be fantastic. Where are you located? Quote Link to comment Share on other sites More sharing options...
Want2race Posted August 21, 2005 Author Share Posted August 21, 2005 Here is a link to some pictures of how the cage in your picture was attached to a Caterham. http://www.teambirkinsport.com/gallery/album27 I checked out your site and your car looks like it will be fantastic. Where are you located? Thanks I'm In GA Thats the most useful site I have seen yet. My only problem is I want to run a full aerodynamics package and that large bar under the car adds substancial weight (15-30lbs) and a huge drag coefiicient. Maybe I can cut something like that into the chassis? Quote Link to comment Share on other sites More sharing options...
