SlowBMW
BMW E36 point assessment question
SlowBMW
I have a 1998 BMW 328is. The car comes with a 2.93 open diff. If I swap in a stock M3 3.23 LSD I obviously need to add +3 points for "added LSD", do I also need to add +3 for final drive ratio modification?
Share this post
Link to post
getfast
Yes. And note it's +6 whether you swap in a junkyard 3.23LSD or a built 4.56 with a Quaife
Share this post
Link to post
SlowBMW
Haha. Okay. Thanks for the quick reply!
Share this post
Link to post
alwaysinboost
Under Section I - No Points Modifications
D4 - Final Drive Ratio Modification
Changing from an open diff to an LSD would be +3.
Modifying an LSD ( like with more discs or different lock-up/ramp rate) would be +1.
If you're just doing a final drive ratio change then its free in TT!
Share this post
Link to post
alwaysinboost
DOAH!!!
Share this post
Link to post
SlowBMW
Good to know. I was asking about NASA-x but will be doing TT as well.
Share this post
Link to post
getfast
No worries. The classing systems are very similar but not exactly the same. Main differences are that all NASA-X classing is "points for parts" based (no TT1-2-3 power to weight dyno stuff), and that a bunch of the no-points mods for TT and PT take points in NASA-X.
If you think of any other questions, fire away anytime, on here or to me privately, jfelton at drivenasa dot com . Also if you need any E36 specific suggestions or advice we have plenty of experience with those cars (and the NASA classing of 'em) around here.
Thanks & hope it helps,
Jon
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
