oregon87 Posted August 20, 2014 Posted August 20, 2014 I've had this car for sale numerous times and each time I had a difficult time letting go and I decided to keep it. Now it needs to go. I'm selling most of my cars, simplifying and moving in a different direction. A new purchase displaces this car and there's no turning back now. Engine: Stock block 347 built by AD Performance Mahle flat top pistons (10.7:1) Comp XE282HR cam/Comp roller rockers World Senior 58cc aluminum heads (2.02/1.60) BBK shorty headers, offroad H-pipe, Flomaster 3 chamber mufflers. Will pass any db test. Edelbrock RPM II intake manifold Accufab throttle body FMS 36lb. injectors Canton road race oil pan, pick up and high volume pump Megasquirt 2 stand alone engine management w/ wide band O2 Misc front engine bracketry to remove A/C, smog pump, etc Brand new Spec stage 3 clutch, pressure plate, TO bearing Lightweight Fidanza flywheel MAC cold air kit MSD 6AL box & coil Remote oil filter with cooler Power steering cooler Summit aluminum radiator Transmission: Standard WC T5 Steel front bearing retainer Rear cluster support plate Road race 5th gear set MGW shifter Rear end Stock 8.8, 28 spline Recently rebuilt with 3.73 gears SN95 Mustang width axles TA Performance aluminum girdle Front suspension: MM sway bar, relocation bracket and support MM K-member MM front offset, SN95 control arms MM coilovers with Koni SA & Hypercoil springs MM camber/caster plates MM strut tower brace MM thru bolt bump steer kit Wilwood 6 piston brakes, 14" rotors MM full length weld in subframe connectors 17" Saleen 5 star wheels with Hoosier 275s Adjustable brake bias control Rear suspension: MM panhard bar MM torque arm MM coil overs wth Koni SA & Hypercoil springs MM adjustable sway bar MM lower control arms MM rear shock mounts Cobra 11" brakes 17" Saleen 5 star wheels with Hoosier 275s Interior: 2 Momo Start seats 6 point harnesses Battery relocated behind passenger seat 12 point rollcage with additional bracing and door bars(painted cage and interior) Autometer gauges Window net Upgraded pedals Quick release steering wheel Gutted doors Custom switch panel (still needs to be wired) Exterior: 3 year old paint H.O. Fibertrends cowl fiberglass hood w/ carbon fiber hood vent clear coated for UV protection Weinerdog fiberglass front end w/ splitter ABS plastic side skirts (mimic the ones from Agent 47) Custom adjustable rear spoiler Lexan rear window The car is located in Bend, OR. I may be willing to travel a reasonable distance to meet a buyer. Please feel free to contact me with any questions. I'm looking for $15k. I will include a nice tandem axle open trailer for an additional $1600. Call or text Dave @ 541-815-4587. http://gotbluemilk.com/web130927/23/imagepages/image3.html Quote
aussiebj Posted September 1, 2014 Posted September 1, 2014 If I can sell my 88 944 turbo S track car ill be all over this Quote
oregon87 Posted September 2, 2014 Author Posted September 2, 2014 Get that 944 on Pelican and get it sold! If it doesn't sell soon, I'm going to have to keep it. Quote
oregon87 Posted September 2, 2014 Author Posted September 2, 2014 Reasonable offers considered. Bought a new car and hate the thought of storing this one outside. Quote
