FS: ls6 miata hpde track car (northern CA)
orion4096
SOLD
$26,000. The price includes any other spare parts I'm forgetting, and potentially a 16' open carson car trailer (dual axle, electric brakes on one axle).
Update: $22,000. No trailer, no extras, no wings, only one set of wheels.
1995 miata
2004 ls6 crate motor
02 camaro ecu running a speed density tune
y-body style accessories (water pump, alternator, tensioner)
ported afr 205 heads. upgraded dual springs. arp head studs
231/234 comp cam - under 600 lift
kooks long tube headers
fast 92 manifold + tb
ati stock size damper
v8r lsx swap kit
updated v8r rear hubs
450+ whp on 91 octane
tc design chromoly cage
schroth belts
tc design custom mounted seat for tall people who don't normally fit a miata
omp grip driver's seat
2-port halon fire system
racepak iq3 dash logger
2x racepak usm for oil temp, pressure, etc
racepak obd module for water temp and other sensors
lithium (lifepo) battery. always stored off the car and charged
painless engine wiring harness
painless toggle switch and relay power harness
setrab oil cooler
lingenfelter oil adapter + 10AN lines.
949 xida cs coilovers
birchwood splitter
apr gtc-200 wing
v8r 11.75" brake kit with the smaller piston dynalites up front and dynapros in back. prop valve installed by driver
~4lbs carbor fiber top (skin) painted to match car. lexan glass. bolts into cage mounts
949 lexan windshield
fm front v8 sway bar. msm rear sway bar
autokonexion front bumper and fenders. rear fenders bolted into oem fenders
depowered PS rack
gto t56 rebuilt by me (new 3,4,5 gears, synchro housing, blocker rings)
monster twin disc clutch with light flywheel
aluminum driveshaft
ford 8.8 (iron housing) lsd 3.27 gears
949 15x10 Nickel 6ULs w/ hoosier r100 245 tires (heat cycled out)
949 15x9 Silver 6ULs w/ nt01s 225/45. They are several years old. Not sure if they are fast, but they are driveable.
Spacers for 15x9s.
Extras
- steel driveshaft.
- racing extras COT-style wing
- stock 2004 ls6 cam
- accusump, lines, and fittings
- shorty headers with midpipes to connect to exhaust
- various mufflers
- lots of other stuff I'm forgetting
This is my HPDE/toy car. Built to be fun and not necessarily fit into any particular racing class. I did not do the original engine swap, but have
removed and installed pretty much everything on the car including the engine, transmission, and differential. It's seen about 10 track days on the
new crate motor. Selling because I need to take a long break from the track and car projects.
  • 1 month later...
