Super Unlimited winning race car for sale
bhtaco21
This car began life as a late model stock car built for short-track asphalt racing at Motor Mile Speedway and Martinsville Speedway. In conjunction with Patrick Henry Community College Racing College director Talmage Thomas, owner Butch Hamlet went about converting the car from left-turn only to a prime time road racer. Now optimized for Virginia International Raceway (VIR), it is a full-blown winning NASA Super Unlimited racer.
Examples of modifications done to this car include moving the engine back 5 inches, lowering the engine, modifying suspension to allow the ride heights to be much lower than normal, building stainless headers and totally removing all exhaust system except headers, lower numerous bolt on items, etc.The engine was built by, and is maintained by, Danny Glad. Danny was head engine builder in Winston Cup for Alan Kulwicki and Wood Brothers Racing. It is a nice compromise between maximizing horsepower and bulletproof reliability. It produces 640 HP and 550 lb/ft of torque at the crankshaft and 592 HP and 490 lb/ft of torque produced at the rear wheels.
After four years of development, the car is now fully sorted. It is on a seven-race winning streak in the series at VIR, and has won all nine races it finished. It took pole in all eleven races. Early in its development, it suffered two mechanical DNFs. The competition in the class includes a $400,000 Porsche GT3-R, Trans-Am cars, GT1 cars, Sprint Cup, Nationwide and ARCA cars, and a Riley and Scott Daytona Prototype. Twice in the series of wins, the car has lapped the field. In this class at VIR, 2:00 is considered a quick time. This car has run in the 1:50’s and a switch to radial tires should cut those times to 1:48’s.
The car is race ready and considering its prior success, the next owner should be in prime position to continue the car’s winning ways in the NASA Super Unlimited or have the loudest, baddest, fastest track day car out there!! Email me for links to in car video. They are really cool to watch (and be sure to turn the volume up!).
Townsend 2006 late model stock car chassis (highly modified and optimized for light weight)
Body – 5 star 2010 LMSC body (far superior aerodynamically to the 2014 bodies)
Composite front splitter
Custom made side skirts
COT rear wing (optimized for front/rear downforce balance)
Carbon fiber louvers on front fenders/hood
5 star cowl induction system
5 star side window deflectors
Chassis custom modified for passenger seat (currently not installed)
C & R radiator w/ integral oil cooler
8:1 Sweet steering box with optimized valving
KRC magnesium power steering pump and integral reservoir
Speedway Engineering heavy duty wide-5 hubs
Low drag hub seals and bearings
Front calipers – Stoptech 4 piston (by Pro Systems)
AP rotors
Penske 7500 shocks X 4
Brand new Powermaster alternator
Carb – road racing Holley 850 cfm
HVH tapered spacer for carb
Profab custom made stainless steel headers (no exhaust system for extra clearance)
Dry sump oil system with Peterson tank and filters
Raceline 3-stage oil pump
Edelbrock custom ported and polished intake manifold
Roller rockers
Rodex aluminum CNC heads, custom ported and polished
KRC pulleys and brackets for front of engine
Brown and Miller oil lines
Engine dynos at 640 hp and 550 lb-ft torque
Quartermaster aluminum bell housing w/ Quartermaster reverse starter
Small diameter flywheel to match bell housing and starter
Quartermaster 7.5 inch 3 disc clutch
Tex Racing T101 4-speed transmission with Long shifter
Wilwood master cylinders with balance bar
Coleman pedals
Sweet steering column
MSD ignition
Nelson main electrical cut-off switch
FireBottle fire suppression system
Autometer Pro-Comp tach
Autometer Ultra-lite water temp and oil pressure gauges
Idiot lights for oil pressure and water temp
Custom made carbon fiber switch panel and dash
Parker Pumper fresh air pump for helmet air
Schroth 6-point seat belts with cam lock release
Lajoie seat with Butlerbuilt halo restraint system
Brand new Braille super lightweight battery
Winters quick change rear with thermal coating
DPI tru-track differential
Lightweight axles
Speedway Engineering drive flanges w/ titanium bolts
Super heavy duty custom made panhard bar mount
Rear anti-sway bar (customized for proper balance)
ATL 22 gallon fuel cell
Brake light
Tow hooks front and rear
$65,000
email me for lots of high res pictures and in-car video
[email protected]
thanks
Butch
