philstireservice Posted September 20, 2014 Share Posted September 20, 2014 http://www.apexraceparts.com/EC7-18-MUSTANG-RS.jpg $319 plus shipping Apex Mustang 18x9.5 ET35 wheel with Toyo 275/35R18 packages available........ Specifications Diameter: 18" Width: 9.5" Offset: 35mm Backspacing: 6 10/16" Lug Pattern: 5x4.5" (5X114.3mm) Centerbore: 70.5mm Weight: ~21.5lbs Profile 2 Available in 3 Finishes: Race Silver Anthracite Satin Black EC-7 Features & Benefits Three unique 18" fitments specific to the Ford Mustang Avoids the necessity to adapt a single offset and width that is dependent on spacers Minimizes the requirement for spacers to achieve a perfect fit Spoke design and barrel work together to create additional brake clearance Lipless design Maximizes strength in the most vulnerable area of the wheel Greatly reduces bends and damage from small impacts Mustang specific center bore - no centering rings required Clears most big brake kits Large race lug openings Accepts oem size lug nuts and large race nuts No tuner lugs needed APEX EC-7 wheels are JWL tested and VIA certified Each size and fitment is tested and certified Factory Fit Designed for Mustang applications, the EC-7 accepts TPMS sensors, 21 mm factory lug bolts or stud conversion kits, and OEM center caps All wheels come with APEX center caps. Lug recesses are unpainted Lug recesses are never painted, preventing wheel bolts or lug nuts from loosening Mounting wheel's does not damage the wheel's finish Manufacturing Just like the rest of the APEX wheel line, the EC-7 is produced using the Flow-forming technique. Flow-forming, which has also been called 'spin forging', produces a barrel with similar strength to that of a fully forged wheel. This significantly reduces weight in the barrel, which has the greatest impact on rotational mass and performance. By combining the strength of a forged, lightweight barrel and a more robust face design, we've produced a wheel that welcomes endurance racing, hard driving, and even potholes. Quote Link to comment Share on other sites More sharing options...
philstireservice Posted October 7, 2014 Author Share Posted October 7, 2014 http://myemail.constantcontact.com/New-Apex-Mustang-wheels-from-Phil-s-Tire-Service.html?soid=1104089983224&aid=PDFCMVLcMXo Quote Link to comment Share on other sites More sharing options...
