FS: Spec3 Race Car (1993 BMW 325is)
dbgeek
Recent family events dictate that it is time to sell the race car. This car was built to the NASA Spec3 rules and is a strong competitor when driven well. Currently asking $14900 for everything. If you want a lower price, we can talk about removing items from the sale. My cell number is 757-8niner7-28five3, feel free to text or call. Located in Chesapeake, VA
I will be listing my open wood deck trailer and 2008 Pathfinder when the race car sells, so if you want the whole go-to-the-track package, we can talk.
Suspension
• Spec3 suspension package
o Koni shocks
o Vogtland springs
o Eibach swaybars
o Vorshlag camber plates
o M3 strut housings
o M3 control arms
• Bushings replaced
o Rear lower outer ball joints
o Rear trailing arm bushings + shims
Reinforcements
• Rear subframe
• Rear swaybar tabs
• Rear lower control arms
• Front subframe reinforcement
• X-brace
Safety
• Competition Cages (Chris Schimmel) full cage with foot protection
• Kirkey Full Containment Seat and mounts on steel floor mount
• G-Force 6-point cam lock harness (2015)
• Fire extinguisher + mount
• Allview mirror
• Longacre spot mirror
• TeamTech right side net
• Window net
Drivetrain
• New Sachs clutch and Luk Flywheel
Engine
• Spec3 chip
• Spec3 exhaust
• Removed A/C
• Vorshlag nylon engine mounts
• Vorshlag transmission mounts
• Electric fan, clutch fan delete (operates auto and with A/C button)
• Bimmerworld Oil Distribution Block
• New Vanos Orings
• K&N filters (2)
Wheels/Tires
• Comes with 10 Spec3 legal wheels and 1 set of crappy street wheels/tires to hold it off the ground between races
• 1 set Toyo RRs with one 30 minute session
• 1 set Toyo RA-1 Full tread (2 scrubbed, 2 sticker)
• 8 used Toyo RA-1 unmounted
Misc
• AMB transponder on Fog Light Switch
• Bimmerworld bullet nose wheel studs
• Momo Mod 78 steering wheel
• Rogue Engineering Quick Release
• Fuel pump 2012
• Reman brake calipers 2012
• Brake ducts (previously mounted, not currently)
• Gauges (oil temp, water temp, oil press)
• Traqmate Complete
• Cool shirt and cooler (additional, mounts on passenger floorboard with existing bracketry)
• Euro Cooling Kit (additional, not installed) – gets rid of the tank behind the radiator
• Battery 2013
Spares
• Brake rotors and Spec3 pads (Hawk DTC60)
• 413 DME
• Guibo, bolts, misc seals, etc
• Front hub
• 4.91 diff (LSD removed)
• Caliper rebuild kits
• Stock Exhaust, a/c parts that were removed
  • 3 weeks later...
  • 1 month later...
