redefinedm3 Posted October 15, 2014 Share Posted October 15, 2014 2001 BMW M3 TIAG on dove grey interior. Currently the car has racing seats installed and the rear seats and panels removed but they will be replaced before the sale. Those interior parts will be available after the sale if the buyer does not wish to include them in the purchase. The stock interior is in excellent condition, no rips, tears, or marks. The front seats are power & heated. The car has just over 118k miles on it and 99% of the work and parts listed below have been done within the last 2k miles. Within the last 500 miles I also sent an oil sample out to Blackstone laps for testing. Everything reported excellent! Purchase Options: $17,000 - Stock interior & iForged wheels $18,500 - Stock interior & SSR Comp wheels with new tires $22,500 - Everything listed below including the 'Optional Purchase' sections. The only reason I'm tossing this up for sale is to start a spec e46 build. With that being said I am open to partial trade for a 2001-2005 330i manual. Valve Adjustment - Nov 2013 Valve Cover Gasket Valve Cover Grommet Set A/C Belt Oil Constant Pressure Valve Thermostat Connecting Pipe O-Rings Vanos Sealing Plate Vanos Solenoid Beisan Systems Pack Vanos upgraded bolts Oil Cap Rear Subframe Reinforcement Plate Kit Rear Subframe Welded Rear Subframe Bushing Set AKG Poly Differential Bushing Set AGK Poly RTAB Bushings AKG Poly NGK Spark Plugs Guibo Re-Timed engine after vanos was removed, cleaned, upgraded, and inspected. Markert Motor Works Tune OEM LED Tail lights AutoSolutions Short Shift Kit Ground Control Rear Camber Arms Stoptech Steel Braided Brake Lines PSS9 Coilovers Turner Motorsports Camber/Caster Plates Front Upper Spring Perch with Bearing CSV Delete Royal Purple Tranny Fluid AFE Intake Exhaust - Resonator replaced with AR20 resonators & rear muffler delete. Hotchkiss Front Sway Bar Mason Engineering Aluminum Front Strut Bar Performance Friction PFC08 Front & Rear Brake Pads New Front Blank Rotors New Rear Blank Rotors (Not installed still in box) Euro Crossdrilled/Floating Currently Installed Liqui Molly 10w60 Motor Oil Mahle 187D Oil Filter External Temperature Sensor - Wired in and tied up so it will not break again. 2005 M3 Bumper w/ New Mesh Grill. Paint Matched Bumper Reflectors Black Kidney Grills Black Fender Grills Fog lights removed but in 100% working order - will come with the car. 19" iForged Rev Wheels - Need refinished, not bent but missing some bolts and currently plasti-dipped. Has tires on them but needs new ones. Rears are almost to wear bars and fronts are miss matched Weighted ZHP Shift Knob Optional: D-Force 18x9.5 et35 wheels Nitto NT01 275/35/18 Tires SSR Comp 18x9.5 et35 wheels Dunlop Direzza ZII 275/35/18 Tires Kirk Racing 4 Point Roll Bar - Bolt In Racetech RT4009W Driver Seat Schroth Profi II Belt Driver Side VAC Motorsports Floor Mount Adaptor Driver Side VAC Motorsports Lap Belt Brackets Driver Side Rachtech RT4000 Passenger Seat Schroth Clubman III Passenger Side VAC Motorsports Floor Mount Adaptor Passenger Side VAC Motorsports Anti-Sub Mounting Bracket Passenger Side VAC Motorsports Lap Belt Brackets Passenger Side TRM Shift Knob I think I've covered everything but as usual I'm sure I left something out. I can get pics or videos of anything you want/need so just let me know! Also this is my first post on here so if anyone needs a shop to verify the car I'd be happy to do so. I can also give some shop owner names and numbers so you can talk to them. Thanks! Quote Link to comment Share on other sites More sharing options...
