Speed Demon Posted October 17, 2014 Share Posted October 17, 2014 Yes I know first post. The car is also listed on LS1tech where I have been a member for many years. 1999 SS Camaro 73.5k mi, H/C, Moser 12 bolt See pics and info at link below. https://drive.google.com/folderview?id=0B5XR5O9KskWNcU5PSFFvSGxndFE# 06-10-2014 12:09 AM by Speed Demon Year: 1999 Make: Chevrolet Model: Camaro Price: $9990 Mileage: 73500 Private or Dealer Listing: Private Listing Location (State): NC Color: Black Transmission: Manual Drivetrain: Rear Wheel Drive 1999 SS 6spd Camaro 73.5k miles $9,990 One owner car. The car is set up for road racing/track days/time trials New Engine, less 100 miles on it. 5.7 block /w forged rotating assembly, TEA heads, Comp Cam 228/232 .588/.595 112LSA LS6 intake,Ford Motorsports 30lb/hr injectors Accusump, Improved Racing windage tray,new o2 sensors, oil cooler, ls6 ported oil pump, new wires, plugs Moser 12 bolt /w 4:10 gears Star Spec Stage 3 clutch & slave cylinder Addco Chorme-Moly Adj Panhard Bar /w rod ends 1" Hotchkis Lowering Spring set Koni SA single adjustable sport shocks Front Koni SA single adjustable spot shocks rear Hollow sway bars (front 35mm, rear 22mm) Carbeau FX1 Pro Seat Carbeau FX1 Seat LS6 intake Pace 85MM MAF kit 85MM BBK throttle Body (RPM) Pro 5.0 shifter Billet aluminum shifter knob Wolf 6point chromoly roll cage – welded in Brake proportioning valve /w ABS delete block BMR Strut Tower Brace Optima Red Top battery BMR Tubular rear lower control arms Sphon torque arm /w driveshaft loop 5 point harnesses for both seats with cam locks Exhaust Cutout Trans oil temp gauge Engine oil temp gauge Quote Link to comment Share on other sites More sharing options...
