qwertymess Posted October 20, 2014 Posted October 20, 2014 Selling the vette to get into the GTS challange with NASA for 2015. The car runs great with zero issues. and is located in Chicago. The motor was refreshed in the winter of 2013/2014, and has only ran a few track days since. I am asking $35,000.00 for everything. Please PM me if you have any questions. This is a turn key race car ready to go. Please email me with any questions: [email protected] Turn Key Ready to Race Today!! -Fire Suppression Installed -New 6 point and 5 point harnesses for 2014 -Motor was refreshed this past winter with only 3 track weekends on it -Makes 592 HP and 512 TQ -C5R Block and C5R Heads -2 Sets of Rims and Tires -Phoenix Pro Built Cage -Clean Title in hand -Brand new Front and Rear LG G1 Sway Bars with LG End Links -Brand New AP Racing BBK up front -ARE 10Qt Dry Sump System -This car needs nothing. Its is a turn key ready to race today Race Car! -NASA or SCCA Ready!" Additional Specs Below: 2002 C5R Z06 Track Car C5R block and heads -- LS7 GM performance division 439 c.i. Bore size 4.155 4" stroke New J.E. Pistons Callies crank connecting rods are Dyers roller mechanical cam shaft by Comp-cams 592 RWHP 512 RWTQ New LS7 coils Beck intake kerry hitt body Phoenix cage DRM BMC AP Racing Endurance front brakes, Z06 stock fronts on rear 2 piece AP rotors front and AFX rear pfadt engine mounts, trans mounts LG G1 Sway Bars and End links front and Rear pfadt mono ball suspension bushings Mcloud multi disk -- with new aluminum flywheel new just installed GM 3:42 gears billet gear transzilla trans from rockland standard CR radiator with fan, separate oil cooler nascar size oil filter ,dry sump engine, new starter, new rear tie rods ARE 10 Qt. Dry Sump Moton 4 way coil overs with remote reservoirs 2 sets of CCW wheels one with Hoosier slicks and other with new Pirelli rain tires (both F- 18x11 and R- 18x13) 315/30/18 Fronts 335/30/18 Rears 2 race seats with 6 and 5 pt. harness - Sparco Pro & Kirkie aluminium racing seat Brand new 6 point and 5 point Race harness installed for 2014 New differential just installed Upgraded ZO6 case Quiffe with 300m hardened shaft DTE Billet Pinion New cooler and filters also replaced Diff and Transmission Coolers Battery Kill Switch Fire Supression New Window Net SFK Hubs with APR Studs New Front Spindles installed New K&N Filters Only 12k miles on Chassis 3 Track Weekends on Fresh Motor Quote
