FOR SALE OR TRADE 98 MUSTANG RACECAR
Yellow Snake
FOR SALE OR TRADE 98’ SVT MUSTANG COBRA RACECAR. COMPLETE OR WILL SEPARATE.
25,538 original miles on car. 301.20 RWHP 294.58 RWTQ. Over $58,000.00 invested.
ENGINE AND DRIVETRAIN
4.6 L Teskid Block
Canton oiling system pan, cooler, thermostat, remote oil filter w/Fragola S.S. lines & fittings (Redline Oil)
Accusump 3 quart w/electric solenoid
Modified BBK 62mm throttle body w/matched intake
Walbro 255 LPH fuel pump
BBK adjustable fuel pressure regulator
WMS C.A.I.
Pro-M 87 mm MAF
BBK LT ceramic coated headers w/stage 8 bolts
BBK off road H pipe ceramic coated
Flowmaster ceramic coated mufflers
MSD DIS-4 w/MSD coils and Thunder Volt 10mm wires
Braille light weight battery
Taylor 4 pole master disconnect switch
Auto-Rod Controls master switch panel 8 positions
Custom crankcase breather system
LFP/Fluiddyne 4 core aluminum radiator
Meziere electric water pump
SCT X3 Tuner
Steeda billet clutch quadrant and firewall adjuster
Innovators West underdrive crankshaft dampener
Ford racing aluminum driveshaft
HPM driveshaft safety hoop
Torsen T-2R limited slip diff. 31 spline
Moser 31 spline axles w/ARP studs
Moser aluminum rearend cover
Ford racing 3.73 and 4.30 gear sets
Pro- 5.0 shifter
Ford Racing A/C delete
SUSPENSION AND CHASSIS
Complete 1 ¾” D.O.M. racing roll cage with foot well protection
Custom 1 ¾”D.O.M. front & rear bumpers
Custom upper steering shaft w/removable steering wheel
Flaming River lower solid steering shaft
ASP solid motor mounts
ADDCO front sway bar w/Steeda aluminum mounts
Kenny Brown matrix subframe connectors
Complete Maximum Motorsports track package
Koni double adjustable coilovers
BRAKES
Front Brembo 4 piston w/Hawk DTC 70 pads
Rear stock w/Hawk DTC 60 pads
Baer 2 piece rotors front & rear
Spare Brembo front & stock rear rotors
Russell S.S. brake lines front & rear
Quantum Motorsports brake cooling ducts
WHEELS AND TIRES
4 18X9.5 2000 Cobra R wheels and 4 18X9 & 18X10 Ford GT wheels w/295 & 305 Toyo R888’
EXTERIOR AND INTERIOR
Complete set of Pro Glass molded Lexan windows still has protective coating
Cervinis 2000 Cobra R front bumper cover
Ford Racing 95’ Cobra R hood w/billet hood pins
Cobra Sebring Pro Kevlar w/side alloy mounts FIA certified
Simpson 6 point FIA harnesses
G-Force window net
Momo steering wheel
Longacre 14” convex mirror
SRP racing pedals
Autometer Phantom gauges
CONTACT JERRY AT [email protected] or 605-351-7110
