tanjulio Posted February 24, 2015 Author Share Posted February 24, 2015 Si 1-2, ZC 3-4, Si 5th (closer 2-3 shift, 5th doesn't run out so quickly; this with a MFactory 4.5 or 4.7 would work) ZC 1-4, Si 5th (basically a GSR trans for a D-Series; this with that 4.5 FD or 4.7 would be great too) ILIKETODRIVE I just see one option for the 91 Transmission...4.9 Final drive. the FD you suggest is for a 92-00 civic transmission. http://www.teammfactory.com/final-drive-gears_94 1: Perhaps there is another company that sells 'clutch type limited slips? Okay.. so I'm still learning.. 2: Are BOTH the final drive and limited slip attached together OR are they separate units that have to be purchased separately ? Thanks.. Quote Link to comment Share on other sites More sharing options...
ILIKETODRIVE Posted February 24, 2015 Share Posted February 24, 2015 Hydro final drives and differentials fit Si/ZC cable transmissions, if I recall correctly. I don't recall the exact things needed but on D-Series.org there is a boatload of info between Aquafina and Mista Bone that would be able to sort it out. There is a marking on the transmission near the passenger axle seal that tells you what type of gearing/case it is. It's a circle with some combination of letter and numbers. I do remember this part being critical. The differential and final drive are separate units. The ring gear, which is 1/2 of the final drive, is bolted to the differential. The countershaft (output shaft) is the other 1/2 of the final drive. For simplicity, yes, Si gearing with a 4.9 would be best. Quote Link to comment Share on other sites More sharing options...
tanjulio Posted February 25, 2015 Author Share Posted February 25, 2015 ILIKETODRIVE. thanks Looks like I have some homework to complete.. i'll work on getting this transmission sorted out. Thanks for everyone's input... Quote Link to comment Share on other sites More sharing options...
