John Mueller Posted February 26, 2015 Share Posted February 26, 2015 NASA Spec Miata has approved some competition adjustments effective March 2 2015: The 1.6 cars minimum weight will reduced by 25lbs to 2275.00lbs ( or 2290.00lbs with overbore)The 2001+ cars minimum weight has been increased by 15lbs by to 2415.00lbs (or 2430.00lbs with overbore)There will not be a restrictor plate change on the 1994-97 cars at this time. As currently configured this model has won races in several NASA regions. Quote Link to comment Share on other sites More sharing options...
Diller Posted July 23, 2015 Share Posted July 23, 2015 Any more thought given to opening up the NA1.8 restrictor to the SCCAs 47mm plate? Quote Link to comment Share on other sites More sharing options...
John Mueller Posted July 23, 2015 Author Share Posted July 23, 2015 Any more thought given to opening up the NA1.8 restrictor to the SCCAs 47mm plate? Not at this time. In some NASA regions the NA8 still can be a dominant car. Quote Link to comment Share on other sites More sharing options...
ILIKETODRIVE Posted July 23, 2015 Share Posted July 23, 2015 Any more thought given to opening up the NA1.8 restrictor to the SCCAs 47mm plate? Not at this time. In some NASA regions the NA8 still can be a dominant car. As an outsider looking in: Doesn't that speak more to driver skill/level of car prep instead of maximum possible ability? Quote Link to comment Share on other sites More sharing options...
John Mueller Posted July 23, 2015 Author Share Posted July 23, 2015 Any more thought given to opening up the NA1.8 restrictor to the SCCAs 47mm plate? Not at this time. In some NASA regions the NA8 still can be a dominant car. As an outsider looking in: Doesn't that speak more to driver skill/level of car prep instead of maximum possible ability? Actually it speaks more to the tracks... Parody is fine at the moment but thank you for you questions. Quote Link to comment Share on other sites More sharing options...
