Jerome
FS: Factory Five Racing 818S #67
Jerome
Yes, I'm thinking about selling my Factory Five Racing 818S. I have over $35K invested (see link for Excel spreadsheet below for a breakdown of most costs). Basically, everything is done and it is a VERY solid car. It just needs some finishing touches (painted/wrap/dip and finish the interior). This is chassis #67 and has an Arizona assigned VIN number. As far as I am aware, it was the first and may still be the only one registered/titled in Arizona.
NO trades. NO tire kickers. Seriously interested parties only. No test drives unless you have a cash deposit in hand.
Priced for a quick sale: $27,500
Contact me directly: JeromeS13@gmail.com
Spreadsheet Link
Build Thread Link
Loads of Pictures
What it needs:
Fit the new bumper (I haven't installed it yet)
Minor fiberglass work to prep for paint/wrap/dip
Finish interior (painted, carpet, etc)
Parts list (I'm sure that I'm forgetting a couple of things):
Engine
LIC Motorsports B1 Short Block (2.5L)
B25 Heads (’06 WRX)
Supertech Valves / Springs / Titanium Retainers
LIC Motorsports Timing Belt Idlers
LIC Motorsports Air Pump Delete Kit
ARP Head Studs
Gates Timing Belt Kit
Grimmspeed Crank Pulley
Cosworth TGV Deletes
Moroso Oil Pickup
OEM ’06 WRX Oil Pump
Tomei Turbo Inlet
Custom Extended Intake / Exhaust (Fathead Fabrication)
JDM VF37 Twin Scroll Turbo / Header / Uppipe
Boyd Welding Aluminum Fuel Tank
Cusco Engine Mounts
FrozenBoost Type 15 Air-to-Water Intercooler
FrozenBoost Type 100 Heat Exchanger
Jabsco 50840-0012 Intercooler Pump
Ron Davis Dual Pass Radiator
Perrin Fuel Rail Kit
TurboSmart FPR-1200 Fuel Pressure Regulator
Injector Dynamics 1000cc Injectors
Aeromotive 340 Fuel Pump
TurboSmart Vee Port Blowoff Valve
Cobb Accessport w/ Snail Performance Pro Tune (on e85)
NGK LFR7AIX Spark Plugs
ReplicaParts.com Alternator Mount Kit
ReplicaParts.com Brake/Clutch Master Cylinder Remove Reservoir Kit
Zero Decibel Motorsports Upper Coolant Reservoir Relocation Kit
Zero Decibel Motorsports Upper Radiator Brackets
Duracell Mini Battery (11 lbs)
Innovate LC-1 Wideband AFR Controller
Suspension/Drivetrain
VeryCoolParts Trailing Arms
Whiteline Rear Lateral Links
ARP Wheel Studs
VeryCoolParts K-Tuned Shifter
Cusco Transmission Mount
Rori’s Shifter Rod Arm
Rori’s Push/Pull Bracket
Brakes
OEM 4/2 Pot Brakes (’06 WRX)
Centric Premium Rotors
Centric PosiQuiet Pads (Street)
Hawk Blue Pads (Track)
Stainless Braided Lines
ATE Type 200 Brake Fluid
Exterior
Enkei Kojin 17x8 +45 (10mm spacers) Front
Enkei Kojin 18x9.5 +45 (13mm spacers) Rear
Federal 595 RS-R 235/40/17 Front
Federal 595 RS-R 265/35/18 Rear
Interior
AiM Sport MXL Pista Digital Dash
Sparco 353 Steering Wheel
Sparco Steering Wheel Hub
Sparco Ergo M Driver Seat
Sparco Evo II Passenger Seat
Rori’s Steering Column Spacer
Sparco 6 Point Harnesses (Driver is HANS version)
K-Tuned Black Shift Knob
Share this post
Link to post
Jerome
Price drop. $26K
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
