Sign in to follow this
Burnett
2010 Mustang for sale, AI, ST3, HPDE, SI starter
Burnett
I have a 2010 Mustang racecar for sale, American Iron AI / ST3 / track day or Spec Iron SI starting point.
It was built from a 2010 BIW. It has a 4.6L 3V that has a 5.0L stroker crank & rod kit. It has Ford racing heads, cams, valve covers, intake, throttle body and oil pan. An SCT tuner with custom tunes for max and reduced power of 395-365 at the tires respectively.
The transmission is the factory 5 speed with a stock 2 piece driveshaft and a Torsen T2R and 355 gears.
The rear suspension has Steeda upper and lower rear control arms, relocation brackets, springs and watts link. The front has Steeda control arm relocation, bushings, ball joints, bump steer kit, sway bar and springs.
The body has an FR500S cage, jacking rails, Steeda strut tower brace, stock fuel tank, 2 hand held extinguishers, Sparco circuit seat with new cover, stock passenger seat (ballast), factory glass and 2014 hood and fascia with Boss splitter.
Front brakes are Brembo 4 piston calipers on 14in 2 piece rotors, rears are factory calipers on 13in Steeda/DBA rotors. The ABS is FR500S.
Wheels are 17x9 or 18x9 depending on your desired use.
For perspective SI buyers I have all of the original engine parts, stock suspension and 2010 bodywork also available.
Asking $25,000
Please contact Robin at 586-two 4 six-3287 or robinracer21@yahoo.com for additional info.
https://www.flickr.com/photos/26178652@ ... ed-public/
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
