MurrayMotorSports Posted July 29, 2015 Share Posted July 29, 2015 I have a built 4.6 3-valve, built by Springfield Custom Auto Machine. Less than 50 miles on the motor, installed to heat cycle the motor and dyno (339 HP RWHP) -11:1 compression -Bore & Hone Block (w)Torque Plate -Clean Engine Block -New Rod Bearing Set -New Ford 4.6 alum block main bearings -New Piston Set CUSTOM Wiseco 3cc dome w/rings -New Ford 4.6 steel I-beam rod -New Arp main studs 4bolt w windage -New Valve intake -New Valve Seals -New H/L Ford 3v valve spring 4.6-5.4 ands retainer -New Cam Phasers and timing chain All are new parts except, block, crank and heads. For addition money, I have GT500 throttle body, intake delete plates, long tubes and H-Pipe to go with the motor. Ready to go, Mike Rousch can install at his cost. asking $2,600.00 or best offer. Depending on the distance, willing to travel to deliver. Quote Link to comment Share on other sites More sharing options...
Mystic_Cobra Posted July 30, 2015 Share Posted July 30, 2015 Lloyd at Springfield Custom has done good work for me for years. Looks like a great deal. Quote Link to comment Share on other sites More sharing options...
MurrayMotorSports Posted July 30, 2015 Author Share Posted July 30, 2015 Thank you Mystic_Cobra, for the kind post! Quote Link to comment Share on other sites More sharing options...
