Newly built 4.6 3v engine from 2006 Ford Mustang GT
MurrayMotorSports
Built 4.6 3-valve engine from 2006 Mustang GT - Built for Road Racing
I have a built 4.6 3-valve, built by Springfield Custom Auto Machine. Less than 50 miles on the motor, installed to heat cycle the motor and dyno (339 HP RWHP)
-11:1 compression
-Bore & Hone Block (w)Torque Plate
-Clean Engine Block
-New Rod Bearing Set
-New Ford 4.6 alum block main bearings
-New Piston Set CUSTOM Wiseco 3cc dome w/rings
-New Ford 4.6 steel I-beam rod
-New Arp main studs 4bolt w windage
-New Valve intake
-New Valve Seals
-New H/L Ford 3v valve spring 4.6-5.4 ands retainer
-New Cam Phasers and timing chain
All are new parts except, block, crank and heads.
For addition money, I have intake delete plates, long tubes and X-Pipe to go with the motor.
Ready to go, Mike Rousch can install at his cost.
asking $2,600.00 or best offer. Depending on the distance, willing to travel to deliver.
