Members Michael G. 0 Posted November 3, 2015 Members Share Posted November 3, 2015 (edited) Current rule To allow a small safety margin for dyno variance, a forgiveness of 4WHP will be given to cars with WHP greater than WTQ and a -4 factor will be applied to the formula for cars using the averaging method for WTQ greater than WHP. 2015 GTS rules 2015 NASA CCR Proposed change Switch from the fixed factor of - 4 WHP to percentage base. Reason To provide equal value of the margin for different classes, still accommodating the variance. Proposed wording To allow a small safety margin for the dyno variance, a forgiveness of equal to 1% of the average WHP calculated using the online method taken from the highest run during testing. In case if the car is impounded and dyno tested more than once during the event - the allowance is available only first time at the dyno - to align and accommodate the differences with the declared dyno values Edited November 18, 2015 by Guest Quote Link to post Share on other sites
pmk 0 Posted November 3, 2015 Share Posted November 3, 2015 Not against this in theory, but 1% is WAY too small for lower GTS classes. Would vote NO based on the current proposed wording of the rule change. Quote Link to post Share on other sites
7VO-VOM 0 Posted November 3, 2015 Share Posted November 3, 2015 (edited) If the percentage is 2% or higher: YES The proposed rule of 1%: NO EDIT: It should not be a 1 time allowance. Dynos change over time with weather and operator error. Edited November 3, 2015 by Guest Quote Link to post Share on other sites
MPower6er 0 Posted November 3, 2015 Share Posted November 3, 2015 Agree on this change IF you change it to 2%. The reality is, anyone that is cheating by 3% or more will get caught, DQ'd and the level of personal embarrassment will keep them from non-compliance at any future event. A 2.5% variance will not win or lose a race for someone over race craft. A 2% variance should help with the inconsistency of Dyno's we've seen over the years. Quote Link to post Share on other sites
J Smith 0 Posted November 3, 2015 Share Posted November 3, 2015 NO. 1% is not enough, especially considering the huge inconsistency in dynos lately. Either leave it at 4hp or I'm fine with a 2% forgiveness. Quote Link to post Share on other sites
Moderators Zach H. 0 Posted November 3, 2015 Moderators Share Posted November 3, 2015 This rule only works if the dyno used for compliance is accurate and consistent. Over the four days at the NASA ECC my car gained 10hp with ZERO changes to the car. Quote Link to post Share on other sites
scottbm3 0 Posted November 3, 2015 Share Posted November 3, 2015 NO Leave rule as currently written. -Scott B. Quote Link to post Share on other sites
Greg Smith 0 Posted November 3, 2015 Share Posted November 3, 2015 Current ruleTo allow a small safety margin for dyno variance, a forgiveness of 4WHP will be given to cars with WHP greater than WTQ and a -4 factor will be applied to the formula for cars using the averaging method for WTQ greater than WHP. Torque is no longer a part of the GTS equation and hasn't been since 2014. 1% isn't enough, I'd be okay with a 2% or even 3% allowed variance, with a 4 HP allowance for cars that make less than 200WHP. Quote Link to post Share on other sites
bimmerhead 0 Posted November 3, 2015 Share Posted November 3, 2015 If the purpose of the rule is to allow a small variance for compliance, why limit it to the first trip on the dyno? I'm no dyno expert, but I've seen 4HP+ variances amongst pulls in the same session - let alone a day or more apart. As worded, I say "No" to this proposed rules change. Cheers, -jerry GTS3 Western Region Quote Link to post Share on other sites
drhm3 0 Posted November 3, 2015 Share Posted November 3, 2015 NO the current proposal of 1% - not enough allowance for all the variability we have seen with dyno runs. Yes for something similar to the following: Avg HP Allowance = max(4, 2% * dyno run with highest avg hp) Quote Link to post Share on other sites
peter*g 0 Posted November 3, 2015 Share Posted November 3, 2015 +1 on this. I also think there should be some language that protects from people who do this consistently on every dyno (e.g., you get a one time "overage" each season) If the percentage is 2% or higher: YESThe proposed rule of 1%: NO EDIT: It should not be a 1 time allowance. Dynos change over time with weather and operator error. Quote Link to post Share on other sites
jvanhouten 0 Posted November 3, 2015 Share Posted November 3, 2015 For. I posted the same thing last year but at 2%. 1% is way too small, 2% might even be too small. I'd want to see what the variance was on the compliance dynos at VIR where all three runs were run back to back basically rolling starts. Based on what we saw, I doubt many of the three pulls were within 1% even though they were run over a ~3 min span. How can we be held to a higher standard than what the dynos will measure? Quote Link to post Share on other sites
noodlexyz 0 Posted November 3, 2015 Share Posted November 3, 2015 No. I have a Mustang dyno at my shop and I can tell you with 100% certainty that they will read more than 1% different on any given pull. There are too many variables and chassis dyno's have historically never been super accurate. They are a tool for tuning and doing diagnosis, reading HP and TQ is essentially a by-product. The 4hp window in my opinion is too low anyway. -Ryan Quote Link to post Share on other sites
mcdonaldsracing 0 Posted November 3, 2015 Share Posted November 3, 2015 Vote no on this. 1% is too small Quote Link to post Share on other sites
John Graber 0 Posted November 4, 2015 Share Posted November 4, 2015 Against this. No other classes even have the variance and I'd even be happy dropping it all together. Quote Link to post Share on other sites
jvanhouten 0 Posted November 4, 2015 Share Posted November 4, 2015 Just some additional data from East Coast Champs. We were compliance dyno'd (three pulls) on Friday and Sunday on the MCE dyno. The variance between the three pulls was 1.97% on Friday and 2.92% on Sunday. Each pull was taken within 60 sec of the previous one. No change in tune between Friday and Sunday and obviously no change in tune between the three pulls in each compliance check. A dynojet may be able to hold to 1% variance in a lab under controlled conditions but no way in the paddock. Their are way too many variables to control pull to pull much less between different cars. Things like water/oil/trans/diff temp, tire pressure, tire location on drum, tire temp, strap tension, yada^3. We are racers can't be held to a higher standard than the measurement method is capable of. I do agree it should be percentage based rather than fixed, but 1% is way too tight. Based on our data, I would say 3%. If MCE still has the data on their PC, we should get it and see what the variance was on these compliance pulls to come up with a real life number. Quote Link to post Share on other sites
sips56 1 Posted November 5, 2015 Share Posted November 5, 2015 No to 1% but like the idea. Make it 2% and I think this makes a lot of sense. Quote Link to post Share on other sites
jdefelice 0 Posted November 5, 2015 Share Posted November 5, 2015 I say leave it.... we should all be well versed in the dyno inconsistencies, ballast up accordingly and don't let it come down to worrying if you make the hp on the dyno... Quote Link to post Share on other sites
Members John S. 0 Posted November 5, 2015 Members Share Posted November 5, 2015 Against. While dynos at events have been shown to be inconsistent, the same inconsistency applies to all competitors. With that said, 1% truly is too small of a window for this proposal and, as such, I am against it. On the same topic, and submitted by another GTS competitor, where are we on scales, weighing, and a common, repeatable methodology for ensuring that the scales are calibrated correctly at each event, every day? Quote Link to post Share on other sites
Members Michael G. 0 Posted November 5, 2015 Author Members Share Posted November 5, 2015 John, The calibration of scales falls under general NASA tech and regulated by CCR, so another proposal you asked about was re-directed to people in charge of that (not GTS). Dyno calculations are class specific though. The reason for proposal to switch from fixed HP to % was exactly driven by the fact that with 4 HP fixed across all classes - it carries unequal values considering the difference in weigh allowance it translates too. The actual number (1%, 2%,...,10 %) is also for discussion. Michael G. GTS Nat. Dir. Quote Link to post Share on other sites
7VO-VOM 0 Posted November 6, 2015 Share Posted November 6, 2015 The actual number (1%, 2%,...,10 %) is also for discussion. Minimum: 2% Quote Link to post Share on other sites
Members John S. 0 Posted November 9, 2015 Members Share Posted November 9, 2015 John, The calibration of scales falls under general NASA tech and regulated by CCR, so another proposal you asked about was re-directed to people in charge of that (not GTS). Thank you Michael! Quote Link to post Share on other sites
Members Michael G. 0 Posted November 10, 2015 Author Members Share Posted November 10, 2015 By the way, wanted to point as well, that other classes do not have a variance factor - it is all left to the discretion of the competitor - what to claim and how much cushion to have for the dyno and scales... Michael G. GTS Nat. Dir. Quote Link to post Share on other sites
Vmcclure10 0 Posted November 12, 2015 Share Posted November 12, 2015 Ok with 2% if we have to change. Vernon McClure GTS 3 Quote Link to post Share on other sites
