Mustang for sale
Hansenpj
Bought this car new in 2004, 40th Anniversary Edition. It has never been driven in the snow and washed frequently, no rust anywhere. Has been sitting the majority of the last three years while I was in Okinawa. This car has never had any big mechanical issues, just normal change the brakes and tires type stuff. Heat and AC both work just fine. It does have an aftermarket stereo that'll come with it. Head unit W/ remote, 8 speakers' two amps and two 12" subs. Everything is already installed, just removed the subs form trunk for more room. Below are all the modifications that I can remember.
Long tube headers (SLP)
X-Pipe (SLP)
Cat back (SLP)
Cold air intake (BBK)
Throttle body (Power Pipe 75mm)
Fuel injectors (24lbs)
Gears (Morroso/3.73)
Upper intake plenum (Power Pipe)
Aluminum flywheel (Spec)
Short throw shifter (UPR blue thunder)
Line lock (SLP)
Cams (Comp Cams 274)
MAF sensor (Granatelli 80mm for 24 lbs injector)
Clutch (Spec 1.5)
Throttle body spacer (UPR)
Under drive pullies (BBK)
Suspension (all 4 Max speed 2"front 2"rear)
Double clutch adjuster (Steeda)
Kenny Brown Matrix sub frame connecters
Front tires 275 (Nitto NT-01)
Rear tires 315 (Nitto NT-01)
Brake Pads (Carbotech XP12s front and XP10s rear)
Front brake kit (Ford Racing Cobra SVT)
Steel braded brake lines (Ford Racing)
Sway bars, front and rear (Eibach)
Ball joints (Steeda x2)
Tie rod ends (Maximum Motorsports)
Seat rail extender, adds four more inches (Kenny Brown)
Hand held tuner (SCT)
Dyno'd 290RWHP, 298 RWTQ. Have the sheets.
Comes with original brake rotors and calipers, and extra Cobra pads and rotors. A set of Summitomo street tires (245/275) since the NT-01s are for "competition use only". I'll have to see what other parts I still have laying around.
I'd like to get $10,000 which is what it would cost just to buy the above parts and to have them installed. I will entertain any reasonable offers though. Might also consider a trade for an already dedicated track car of similar value, which is what I want to buy if this sells. May also trade for Ford 6.4 diesel or Cumming diesel.
Please feel free to text or call Pete if you have any questions (six five one) 319-2239. Can also email or text pictures
Link to post
