National Staff Greg G. Posted December 2, 2015 National Staff Share Posted December 2, 2015 The 2016 NASA Time Trial Rules are posted on the NASA Rules page. https://www.nasaproracing.com/rules Here is the direct link to the pdf file: https://nasa-assets.s3.amazonaws.com/document/document/4273/2016_Time_Trial_Official_Rules.pdf We still have the 2015 Rules, Dyno Certification Form, and Car Classification Forms posted, but we will post the new 2016 Dyno Certification Form and Car Classification Forms next week. Also, the class calculator tools are being updated for 2016. So, make sure you are not using the 2015 calculator. Please note the significant change to the calculation of horsepower for TT3 this year. We will be using Avg HP instead of Max HP for calculating the Adjusted Wt/HP Ratio. The tentative plan is to move to using this calculation for the TT1 and TT2 classes in '17 if all goes as planned, and possibly for the lower level TT classes as well. Also, we are planning on expanding the TT classes in '17 to include TT4 at 12:1 with possibly a few additional restrictions or Modification Factors, just as TT3 has a few that don't apply to TT1 and TT2). Either way, if we add a class, we will delete a class or classes to prevent field dilution. I will post much more about this in mid-2016. We are also looking at possible lower level classes using a TT5 and TT6 format, along with additional restrictions, Modification Factors, and even a Modification Factor table based on car model. These would eventually be a substitute for most of the current TT classes. They would simplify classing of cars because we would no longer need to do Dyno Re-classes of motor swaps, ported rotaries, aftermarket heads, F/I, etc. We would have significantly less Modification Factors than we currently have for TT Modification Points. However, before we would proceed with these TT classes, we would have to be certain that these classes would retain the ability for competitors to run cost-efficiently as many do in the lower TT classes now. We understand that open rules at these lower level classes just don't make much sense. It doesn't make sense to put $30,000 of mods into a $3000 vehicle to be competitive. Thanks, and have a great season! Quote Link to comment Share on other sites More sharing options...
hispanicpanic Posted December 2, 2015 Share Posted December 2, 2015 Do you have a proposed date for the posting of the 2016 TT calculator? Quote Link to comment Share on other sites More sharing options...
National Staff Greg G. Posted December 2, 2015 Author National Staff Share Posted December 2, 2015 I would think about 7-10 days. Quote Link to comment Share on other sites More sharing options...
ILIKETODRIVE Posted December 2, 2015 Share Posted December 2, 2015 No 2.4L 8-speed DCT TLX base class? Quote Link to comment Share on other sites More sharing options...
Dysenpham Posted December 3, 2015 Share Posted December 3, 2015 So no more -40mm -10pts? Was hoping it is a typo. Quote Link to comment Share on other sites More sharing options...
kbrew8991 Posted December 3, 2015 Share Posted December 3, 2015 Do mirrors count as part of vehicle width? (related to the 6" measurement for aero parts) I really do like the way the loss-of-control rule was tightened up, good work Quote Link to comment Share on other sites More sharing options...
National Staff Greg G. Posted December 3, 2015 Author National Staff Share Posted December 3, 2015 So no more -40mm -10pts? Was hoping it is a typo. Not a typo. Quote Link to comment Share on other sites More sharing options...
National Staff Greg G. Posted December 3, 2015 Author National Staff Share Posted December 3, 2015 No 2.4L 8-speed DCT TLX base class? If nobody requested it, it wasn't classed. Quote Link to comment Share on other sites More sharing options...
National Staff Greg G. Posted December 3, 2015 Author National Staff Share Posted December 3, 2015 Do mirrors count as part of vehicle width? (related to the 6" measurement for aero parts) I really do like the way the loss-of-control rule was tightened up, good work No, mirrors don't count toward vehicle width (must be body). Quote Link to comment Share on other sites More sharing options...
Gian Bowles Posted December 4, 2015 Share Posted December 4, 2015 Greg, a question on Bump steer kits for older strut suspension cars. Were a block is used between the bottom strut and knuckle/control arm/ ball joint. Would that be a +6 point mod? E-13) Relocation of front suspension mounting points +6 (includes modifications to spindles and knuckles that relocate control arm mounting points in space—such as “drop spindles”) But for newer cars it's just +2? E-15) Front steering tie rod bump steer modifications or shimming of the steering rack +2 Quote Link to comment Share on other sites More sharing options...
National Staff Greg G. Posted December 4, 2015 Author National Staff Share Posted December 4, 2015 p.m. sent---referred to e-mail for photos, diagrams, etc. Quote Link to comment Share on other sites More sharing options...
CRallo Posted December 5, 2015 Share Posted December 5, 2015 These are two very different things. Are you adjusting camber gain or bumpsteer? Old cars have tie rods too, so the 2 pt mod applies if done correctly. Greg, a question on Bump steer kits for older strut suspension cars. Were a block is used between the bottom strut and knuckle/control arm/ ball joint. Would that be a +6 point mod? E-13) Relocation of front suspension mounting points +6 (includes modifications to spindles and knuckles that relocate control arm mounting points in space—such as “drop spindles”) But for newer cars it's just +2? E-15) Front steering tie rod bump steer modifications or shimming of the steering rack +2 Quote Link to comment Share on other sites More sharing options...
bikeride Posted December 17, 2015 Share Posted December 17, 2015 Welcome to 2016. The car you have spent the last three year developing now needs to loose 7 points, good luck with that. 7 points is a lot! The new rules added a * to the 01-06 BMW 330. 7 points is a lot. What is involved to get dyno classed to stay in TTD. My dyno is only 200 hp and the rules seem to think I have 225. 7 points is a lot. The first thing that came to mind when I saw the * was Kurt Vonnegut's special drawing in "Breakfast of Champions"... Anyone remember that book? And 7 points is a lot. Quote Link to comment Share on other sites More sharing options...
Members Mike W. Posted December 17, 2015 Members Share Posted December 17, 2015 Welcome to 2016. The car you have spent the last three year developing now needs to loose 7 points, good luck with that. 7 points is a lot! The new rules added a * to the 01-06 BMW 330. 7 points is a lot. What is involved to get dyno classed to stay in TTD. My dyno is only 200 hp and the rules seem to think I have 225. 7 points is a lot. The first thing that came to mind when I saw the * was Kurt Vonnegut's special drawing in "Breakfast of Champions"... Anyone remember that book? And 7 points is a lot. The dyno re-class procedure is clearly spelled out in Section 8.4 of the TT rules. The key is looking at your current modifications and deciding what base class you need for the dyno re-class. Quote Link to comment Share on other sites More sharing options...
ILIKETODRIVE Posted December 17, 2015 Share Posted December 17, 2015 The dyno re-class procedure is clearly spelled out in Section 8.4 of the TT rules. The key is looking at your current modifications and deciding what base class you need for the dyno re-class. This. Add up tires & drivetrain & suspension & brakes/chassis & aero. Determine where your reclass needs to start to end up at or near the top of TTD. Quote Link to comment Share on other sites More sharing options...
bikeride Posted December 21, 2015 Share Posted December 21, 2015 Wow, I read it a couple times and have no idea how it works. No clue at all. It may be clearly spelled out for some far more clever than myself. If I add up all my points, not engine related, I am still good for the class I have been building this car for. That is with my newly awarded 7 point *. The minimum weight/power ratio for TTD is 14.25:1. I am closer to 15.5 or 16:1. Am I eligible for dyno reclassing? I really do not want to spend the rest of the winter undoing a lot of the work I have done. Quote Link to comment Share on other sites More sharing options...
National Staff Greg G. Posted December 21, 2015 Author National Staff Share Posted December 21, 2015 Wow, I read it a couple times and have no idea how it works. No clue at all. It may be clearly spelled out for some far more clever than myself. If I add up all my points, not engine related, I am still good for the class I have been building this car for. That is with my newly awarded 7 point *. The minimum weight/power ratio for TTD is 14.25:1. I am closer to 15.5 or 16:1. Am I eligible for dyno reclassing? I really do not want to spend the rest of the winter undoing a lot of the work I have done. 1) Get a NASA membership if you don't have one 2) Follow the instructions in the rules to request a Dyno Re-class http://www.nasa-tt.com/Rules/p2005_articleid/231 Quote Link to comment Share on other sites More sharing options...
f1honda Posted April 13, 2016 Share Posted April 13, 2016 will TT3 track records be reset because of the rule change this year? Quote Link to comment Share on other sites More sharing options...
National Staff Greg G. Posted April 14, 2016 Author National Staff Share Posted April 14, 2016 Regional Track Records are handled by your Regional TT Director. The changes made are neutral for many of the vehicles that did not have flat HP Dyno curves, but should have resulted in higher weights (or lower HP) for those with the flat HP Dyno's. So, along with vehicle development and tire development each year, it is possible that those older records will still be broken using the new rules. However, if it is clear that the old record in your region is way off now (as in the former record holding vehicle is now way off from that time), it would make sense to reset that record, but I will leave that choice up to your Regional TT Director. Quote Link to comment Share on other sites More sharing options...
Clavette Posted April 15, 2016 Share Posted April 15, 2016 So far, there appears to be no problems for our fast driver resetting TT3 records in Texas Region under new formula. Quote Link to comment Share on other sites More sharing options...
f1honda Posted April 15, 2016 Share Posted April 15, 2016 i have a few track records in our region and i have a flat HP car. i added 120 lbs to the car to bring it to 10:1. would be hard for me to get close to those records although i could use more development on the car. Quote Link to comment Share on other sites More sharing options...
kbrew8991 Posted April 15, 2016 Share Posted April 15, 2016 So far, there appears to be no problems for our fast driver resetting TT3 records in Texas Region under new formula. Texas also still lists TTA records. Honey Badger region! Quote Link to comment Share on other sites More sharing options...
National Staff Greg G. Posted April 19, 2016 Author National Staff Share Posted April 19, 2016 A new TT3 record was set at Buttonwillow (13ccw) on Sunday. Quote Link to comment Share on other sites More sharing options...
erik911 Posted April 21, 2016 Share Posted April 21, 2016 A new TT3 record was set at Buttonwillow (13ccw) on Sunday. And the TT3 record was a scant 7 seconds slower than the ST3 qualifying time... Quote Link to comment Share on other sites More sharing options...
drivinhardz06 Posted April 22, 2016 Share Posted April 22, 2016 will TT3 track records be reset because of the rule change this year? Built to the new ruleset, I would say absolutely. Quote Link to comment Share on other sites More sharing options...
