Sign in to follow this
blueekb
TT1,2,3 tire size question
blueekb
TT1,2,3 rules state this:
Non-DOT approved tires = -0.5(CTSC EC-DryContinentals see App. A)
Size 10.5” (267mm) to 9.6” (244mm) non-DOT approved = +0.3
Size 9.5” (241mm) or smaller non-DOT approved = +0.7
Size 275 to 250 (DOT approved) = +0.3
Size 245 or smaller (DOT approved) =+0.7
But there are two examples given with tires sizes that are larger with no penalty?
Example: 2006 Chevrolet Corvette Z06, with OEM transmission, on DOT approved 345 size
tires, weighing 3000 lbs, with 375 peak rwhp:
3000/375 = 8.0 (TT2)
2003 Dodge Viper Comp Coupe, with OEM transmission, on non-DOT approved
345 size tires, weighing 3600 lbs, with peak chassis dyno power of 642rwhp:3600/642= 5.61, minus 0.5(non-DOT's), plus 0.4
(3600 lbs or greater) = 5.51 (TT1)
Are these just old examples left over from previous rules? My understanding was that 275 was the largest tire I could run in TT3 and there isn't even an option to run a larger tire correct? Or am I missing something where I can run the same size that came OEM? I've seen people run 305 and larger in the past and just wanted to clarify. Thank you.
Share this post
Link to post
ILIKETODRIVE
You can run larger than 275. However, there is not an adjustment in PTW for doing so.
3000/375 = 8.0
There is no adjustment for tires bcuz DOT 345 width (larger than 275)
There is no adjustment for weight bcuz 3000lb-3299lb (adjustments for lighter and heavier than those weights)
Share this post
Link to post
blueekb
Ok I get it now. Running a smaller tire can get you more H-W ratio. Not sure why I was confused lol.
Share this post
Link to post
Clavette
Yeah, I have to run 245's because I need the +0.7 WT/HP adjustment to meet the new 10:1 in TT3.
Denis
Share this post
Link to post
