cash canada
Got a Camaro for Sale AIX / AI / SU / Run What you Brung
cash canada
Go fast on a budget. I cant post picture but will figure it out later.
For Sale: 1982 Camaro Race Car 2009 and 2013 NASA SE AIX Championship winner!
Weight 3217 lbs Wet with 200lbs Driver and full of fuel and fluids and cool suit
Engine
355 cu Small Block Chevy (no junk parts)
Horsepower 539 HP at 6,300 rpms ON PUMP GAS!!!!!!
Block One piece real main seal 4 main ZZ4 roller block
Crank 3.48 stroke GM Steel
Rods 6 inch Manley I beams 578 grams
Pistons Manley Formula Won 355 grams lateral gas ports .043 x .043 v 3mm total seal gapless rings
Heads Air Flow Research 195 with 2.02 / 1.95 valves
Camshaft Solid Roller Custom grind for this car from Mike Jones
Lifters Isky Roller Lifters
Springs Two races on Isky Tool Room Springs
Rockers 1.5 Harland Sharpe with Stud Girdle
Carb Holley 750 dp (works very well)
Intake Holley Strip Dominator
Ignition MSD 6AL with MSD Billet Distributer
Pan 7 1/2 Champ Road Race Pan
Accumulator Moroso 3.5 qt
Cooler Remote Setrab with An 10 and AN 12 lines
Drivetrain
Clutch Powertrain 7.25 inch 3 disc clutch
Trans 4 Speed Jerico with 1.78 / 1.45 / 1.18 / 1.00 ratios
Rear 9 Inch Ford 31 spline axles
Two complete Nodular Iron center sections 3.25 and 3.55 gears both with Eaton Tru Track Diff (Torsen Worm Gear Differentials)
Brakes
Fronts Coleman 13 x 1.25 Rotors and Hats w /Willwood FBS with 1.88 / 1.75 pistons
Rears Willwood 12 x .810 Rotors and Dynolites with 1.38 pistons
Pedals Willwood
Masters Howe
Plumbing All brake line fittings are AN -3 for easy service
Saftey
Belts Current Belts purchased in 2014
Fire Bottle 10 lb system
Fuel System
Tank Stock filled with Fuel Cell Foam
Pump Holley Electric Blue
Regulator Holley
Lines New in 2013 AN 8 Aeroquip lines
Spares Wheels, Tires, Transmission, Differentials, Intakes, Fuel Pumps, Rotors, Pads, Tools & too many others to list
Price $15,500 or BRO
Cash Canada
Charlotte North of SC
803-522-1830
[email protected]
Share this post
Link to post
