Sign in to follow this
synolimit
Columbus Ohio people?
synolimit
anyone in the columbus area? ive got questions if you've got answers. moving from motorcycle racing and into more car HPDE's then onto TT. any experienced drivers or knowledge holders I'd love to pick your brain. been building this for about a year and half...
build sheet
Engine----
OBX LTH with DEI titanium wrap
Motordyne XYZ Y pipe with DEI titanium wrap
Custom single 3" side exit exhaust, 1- 18" bottle res, 1 ultra quiet res
Stillen gen 3 CAI with DEI gold wrap
My dual AOS setup
My PnP TB, upper and lower manifolds
My 48 row oil cooler
CJ motorsports large baffled oil pan
Venting valve vents to atmos
Gas tank cut in half for fuel starve fix
Gas tank vent line with Boyd rollover vent/check valve
Redline 5w30 oil
3qt accusump system
Tuned by Crucial Performance
Drive----
My rear 25 row diff cooler/Tilton pump with temp gauge
SPL solid diff bushings
Drop Eng. poly tranny mount
Redline diff fluid
Redline tranny fluid
Z1 solid engine mounts
Suspension----
Stance 2 way true type coilovers 18k/12k
SPL toe links
SPL traction arms
SPL rear chamber arms
Hotckins front sway bar
Rear sway bar deleted
SPL camber arms front
SPL rear knuckle bushings
SPL front end links
My rear eccentric lock out kit
Traction and yaw kill switch
Brakes-----
Z1 SS brake lines
Front brake cooling ducts
Rear brake cooling ducts
Rbf600 fluid
Z1 2 piece rear rotors
Z1 2 piece front rotors
Carbotech XP12 front pads and XP10 rear pads
ABS system delete with Wilwood proportional valve
Aero----
My front splitter
My canards
My complete flat bottom
My rear diffuser
My front fender vents
APR 71" GT-250 wing chassis mounted
Wheels/tires
RPF-1 18x10.5 +15 square
RS-3's 285/35/18 square
45mm rear spacer with 10.9 hardware
3" ARP extended rear wheel studs
Safety
OMP fiberglass FIA halo seat.
OMP 6 point FIA belt with 2" shoulder straps for Hans device.
Hans III device.
OMP belt with 8.8 ring hardware
10.9 hardware holding seat to raisers and base.
Planted FIA steel base
Planted FIA aluminium raisers.
FIA 1.75" rear roll cage
Misc.
Rear wide body fenders
Deka 11lbs battery
3 quart washer bottle in trunk
Full car air bag system delete
All non essential wires deleted throughout
Vinyl wrapped
AC system deleted along with two pulleys
ABS system deleted
Coming soon
Pneumatic air lift jack system
SPL front impact bushings
SPL front lower arm bushings
SPL rear upper arm bushings
LSD
Slicks
Share this post
Link to post
synolimit
Sad no one lives here
Share this post
Link to post
TLeroux
I thought I told you I was in Dublin when I responded to your questions on classing your car in TT.
Share this post
Link to post
synolimit
You did. And I never got a reply back after I asked some questions 3 days ago. I was also hoping more would respond here for some good conversations.
Share this post
Link to post
scottbm3
Theres quite a few racers and HPDE people in your general area. There's just not a lot of action on this forum.
-Scott B.
Share this post
Link to post
Sterling Doc
What class are you shooting for? ST3?
Share this post
Link to post
synolimit
Shooting for as low as possible but looks like I'll be TTU with frame modification or maybe TT3 if i do all my paper work.
Share this post
Link to post
Jeff D
There aren't many Spec-Z racers but Adam Rawski might be a good person to talk with. Not sure where he's from (and the driver profiles on the web are currently down). A quick glance at the last two events and I didn't see any Spec-Z's, so he might not be running this year, or planning a late start (like me).
Ditto what Scotty B says, not much activity here but quite a few people in the Columbus area. I'm down near Dayton (Waynesville).
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
