synolimit Posted May 2, 2016 Share Posted May 2, 2016 It's prob been asked before but I've got a lot done and within each section do I click more than option? Obviously not in the tire section as you can only run 1 option but do you only get 1 option in the others or multiple. Kinda detailed, hope this helps 2013 370z sport with OEM LSD and big brake kit OEM weight fully fueled- 3365lbs Current weigh fully fueled- 2990 before cage and flat bottom OEM HP- 332 at the flywheel Current HP- 313 at the wheels in 5th, 1:1 ratio, SAE dynojet Engine---- OBX LTH with DEI titanium wrap Motordyne XYZ Y pipe with DEI titanium wrap Custom single 3" side exit exhaust, 1- 18" bottle res, 1 ultra quiet res Stillen gen 3 CAI with DEI gold wrap My dual AOS setup My PnP TB, upper and lower manifolds My 48 row oil cooler CJ motorsports large baffled oil pan Venting valve vents to atmos Gas tank cut in half for fuel starve fix Gas tank vent line with Boyd rollover vent/check valve Redline 5w30 oil 3qt accusump system Tuned by Crucial Performance Drive---- My rear 25 row diff cooler/Tilton pump with temp gauge SPL solid diff bushings Drop Eng. poly tranny mount Z1 solid engine mounts Redline diff fluid Redline tranny fluid Suspension---- Stance 2 way true type coilovers 18k/12k SPL toe links SPL traction arms SPL rear chamber arms Hotckins front sway bar Rear sway bar deleted SPL camber arms front SPL rear knuckle bushings SPL front end links My rear eccentric lock out kit Traction and yaw kill switch Brakes----- Z1 SS brake lines Front brake cooling ducts Rear brake cooling ducts Rbf600 fluid Z1 2 piece rear rotors Z1 2 piece front rotors Carbotech XP12 front pads and XP10 rear pads ABS system delete with Wilwood proportional valve Aero---- My front splitter My canards My complete flat bottom My rear diffuser My front fender vents APR 71" GT-250 wing chassis mounted and above roof line Wheels/tires RPF-1 18x10.5 +15 square (front +51mm, rear +73mm) RS-3's 285/35/18 square 45mm rear spacer with 10.9 hardware 3" ARP extended rear wheel studs Safety OMP fiberglass FIA halo seat. OMP 6 point FIA belt with 2" shoulder straps for Hans device. Hans III device. OMP belt with 8.8 ring hardware 10.9 hardware holding seat to raisers and base. Planted FIA steel base Planted FIA aluminium raisers. FIA 1.75" rear roll cage Misc. Rear wide body fenders Deka 11lbs battery 3 quart washer bottle in trunk Full car air bag system delete All non essential wires deleted throughout Vinyl wrapped AC system deleted along with two pulleys Coming soon Pneumatic air lift jack system SPL front impact bushings SPL front lower arm bushings SPL rear upper arm bushings LSD Slicks Quote Link to comment Share on other sites More sharing options...
National Staff Greg G. Posted May 2, 2016 National Staff Share Posted May 2, 2016 ST2/TT2 or ST3/TT3---Depends on the actual Minimum Competition Weight and Avg HP (or the Max HP plus your choice of amount of room for Dyno variance for ST2/TT2) --see the ST or TT Rules. Also, this calculator is helpful: https://nasa-assets.s3.amazonaws.com/document/document/4423/NASA_ST_U_1_2_3_Class_Calculator_2016_v1.xlsx Quote Link to comment Share on other sites More sharing options...
synolimit Posted May 2, 2016 Author Share Posted May 2, 2016 That calculator has no aero and seems to be missing a lot. Quote Link to comment Share on other sites More sharing options...
National Staff Greg G. Posted May 2, 2016 National Staff Share Posted May 2, 2016 Please read the ST Rules. Your car is in the higher level classes where items like aero and suspension have only a few limitations... Quote Link to comment Share on other sites More sharing options...
trigger Posted May 2, 2016 Share Posted May 2, 2016 the 370Z starts in TTB with * (7 extra points). which means you only have 12 points to play with. I counted about 15 points before even getting to the aero. That said. you are definitely in the TT1/2/3 classes. your car is well setup to play in TT3. if your about 150lbs you would have 3150lbs / 313HP = 10.0 lbs per HP. right at the limit for TT3. read the rules and play with the calculator here https://www.nasaproracing.com/rules Quote Link to comment Share on other sites More sharing options...
synolimit Posted May 3, 2016 Author Share Posted May 3, 2016 the 370Z starts in TTB with * (7 extra points). which means you only have 12 points to play with. I counted about 15 points before even getting to the aero. That said. you are definitely in the TT1/2/3 classes. your car is well setup to play in TT3. if your about 150lbs you would have 3150lbs / 313HP = 10.0 lbs per HP. right at the limit for TT3. read the rules and play with the calculator here https://www.nasaproracing.com/rules What I don't get is like suspension section E. E1 and E2 talk about external res or piggy back external res. Do I pick 1 or both? Having trouble on all these sections cause I'm not sure if I get 1 like tires or I have to pick more? Quote Link to comment Share on other sites More sharing options...
National Staff Greg G. Posted May 3, 2016 National Staff Share Posted May 3, 2016 Scott, You should be reading Section 7 of the TT Rules--pages 6-13, not Section 8. Contact your regional TT Director, Joe Sullivan for assistance. http://www.nasa-tt.com/Regions Quote Link to comment Share on other sites More sharing options...
synolimit Posted May 4, 2016 Author Share Posted May 4, 2016 I don't think my cars legal actually. Unless I classify as a non production car after reading some of that. Quote Link to comment Share on other sites More sharing options...
National Staff Greg G. Posted May 4, 2016 National Staff Share Posted May 4, 2016 I don't think my cars legal actually. Unless I classify as a non production car after reading some of that. That is possible depending on items like tubbing the inner fender wells, etc. The Non-Production Mod Factor is not that large--only -0.4. Like I said, you would be best off speaking with Joe, sending him photos of the modifications in question, etc. While folks are well-intentioned here, you may not get correct answers, and it is best to speak to the guy who is going to inspect your car for compliance. Quote Link to comment Share on other sites More sharing options...
