National Staff Greg G. Posted May 4, 2016 National Staff Share Posted May 4, 2016 TECHNICAL BULLETIN 5-3-16 NASA NP01 in ST Appendix A—Technical Bulletins, Approvals, Assessments for Specific Car Models NP01 (ST3): The NASA NP01 is only permitted to compete in ST3 as follows: 1) The Minimum Competition Weight must be equal to or greater than 1800 lbs. 2) The vehicle must be 100% compliant with all NP Series rules, including the specified Toyo 235 x 17 RR tires. 3) The vehicle may compete in regional competition without having chassis Dynamometer Dynojet pre-competition testing, but the driver/owner must still complete a pre-competition ST Car Classification Form. 4) Competition in a NASA Championship event requires pre-competition Dyno testing. 5) The vehicle is still subject to post-competition Dyno inspection, and must be compliant with the 10.0:1 limit of "Adjusted Weight/Power Ratio". Modification Factors include -0.3 for weight, -0.4 for Non-Production, -0.6 for transmission, +0.7 for tires. NP01 (ST1/ST2): 1) The NASA NP01 may compete in ST1 or ST2, but MUST assess the -2.0 Modification Factor for weight under 1800 lbs, REGARDLESS of the actual Minimum Competition Weight. The vehicle is not restricted to NP "spec" modifications or tires. 2) If the vehicle has a NASA/Elan sealed engine, the vehicle may compete in regional competition without having chassis Dynamometer Dynojet pre-competition testing, but the driver/owner must still complete a pre-competition ST Car Classification Form. 3) Competition in a NASA Championship event requires pre-competition Dyno testing. 4) The vehicle is still subject to post-competition Dyno inspection, and must be compliant with the limit of "Adjusted Weight/Power Ratio" for its class. Quote Link to comment Share on other sites More sharing options...
