msweeney3056 Posted September 14, 2016 Share Posted September 14, 2016 Built on a custom-length chassis with a slightly shortened box and the biggest V-nose possible for maximum interior length while staying just under 25' total length. This was to make sure that this trailer could be towed behind a 40' motorhome legally, staying under the 65' total length restriction. It also does great behind our dually pickup truck. It is very stable and has great brakes, and the v-nose really helps with fuel mileage. The lift is rated for 4000 pounds and has a removable center section that makes miserable jobs like transmission swaps or differential changes at the track much nicer. One-button operation up or down. We have used this trailer since 2007 for local vintage and club racing, and it has been a great setup for us. Build cost was about $60,000, including well over $10,000 in options and custom equipment. The only reason we are selling is the need to bring three or four cars to the track regularly next season. GVWR of 18000. Empty weight is listed as 6000, so maximum payload is 12000. One owner from new Rear Ramp with Spring Assist and built in ramps Third ramp in center of door for loading tool boxes, engine crates, etc Attic in V-nose with four rows of aero-track on the walls and D-rings in floor, plus two inch lip to keep things up there! Aero-track down right side wall for tying equipment, tables, etc Aero track infront of lift on left wall for tying air tanks, etc C-Tech workbench cabinets and over head cabinets on vnose right hand wall Four additional D-Rings in V-nose for tying down tool box Full width tire rack at rear of trailer, with built in rack for tie-downs 4 48" fluorescent lights, 6 dome lights, 2 110V 18" fluorescent lights in attic ceiling External 3 halogen light package Motorcycle chock mounts in floor at rear of trailer, chock included 6000 pound axles (3) Electric brakes on all three axles Brand new tires! .050 Epoxy Exterior Metal Insulated walls and ceiling 4,000 lb Electric Tongue Jack All LED Lights, super bright and very long lasting! LED Fuse Panel 110V Wire Package with 30A Breaker Box 2 GFI outlets inside, 1 outside 12V Battery System AC/DC Converter with exterior plug for shore power 4,000 lb Gemini Lift with Full Floor 12V Roof Vent 4-6″ Round STD Lights Full aluminum floor (standard is plywood) Loncoin rubber floor Aluminum insert for lift .030 Aluminum Sides and Ceiling (interior) Side Access Door Stone Guard Stainless Steel Hinges with Grease Zerk 8 D-Ring Tie Downs in floor and on lift for car tie-down Rear Stabilizer Jacks Aluminum Slide-Out Step 8-lug Wheels Stainless Steel Nose and Stone Guard Height: 12'9" (10'6" interior height) 98" rear door 86" between wheel wells Located in Monterey, CA, can deliver, available immediately. New Price: $37000 Contact Mike at 831-920-1625 [email protected] Thanks! Quote Link to comment Share on other sites More sharing options...
