kazyn Posted October 22, 2016 Share Posted October 22, 2016 (edited) For sale Acura integra track car. Dont have time (money) to ride in anymore. Pickup in NJ 07407. $10999 SUSPENSION PIC coilovers select R3 PCI Rear Trailing Arm Spherical Kit PCI Rear Upper camber link PCI front lower control arm Bronze Bushing ASR rear sway bar - stock front Skunk2 front upper control arms stock OEM rear LCA DRIVETRAIN K24 stock from Acura TSX Hondata KPRO tuned at Xenocron oil pan baffles Acura RDX injectors AEM fuel rail aluminum radiator Hybrid Racing engine mounts 5 speed transmission with 5.0 final drive Exedy 4 puck clutch Kit Exedy light flywheel Kaaz differential oil catch can BRAKES/WHEELS Wilwood front brakes corrado -brembo blanks front rotors brembo blanks rear rotors Hawk race front pads Cheap rear pads braided brake lines extended wheel studs light wheel nuts 6 kosei k1 wheels used toyo rr 225/45R15 INTERIOR/EXTERIOR roll cage with lots of gussets sparco pro 2000 seats schroth seat belts shift light AFR and oil pressure gauges shift light still working power windows and mirrors working headlights carbon fiber hood momo steering wheel with quick disconnect whole chassis was stripped and powder coated light damage to rear quarter panels scratches and chips from track use no transponder no logbooks SPARES hatch with glass cut doors stock k20a3 shortblock for HC2 Edited March 6, 2019 by kazyn update Quote Link to comment Share on other sites More sharing options...
kazyn Posted March 6, 2019 Author Share Posted March 6, 2019 up for sale again Quote Link to comment Share on other sites More sharing options...
