djhedges Posted November 7, 2016 Share Posted November 7, 2016 On the exit for turn 12 at Portland International Raceway as I unwind the steering wheel for the front straight the car pulls to the right. It's a right hand turn in 3rd gear and I've been full throttle for a few seconds. It's just before the steering wheel is fully straight. It feels like something is unloading or unbinding. It doesn't matter how smoothly I try to unwind the steering wheel it always abruptly pulls and then everything is fine. My friends and I are building a 91 Civic Si for chump car. The suspension has new Poly bushings New rubber trailing arm bushings New struts New lower ball joints New tie rod ends New steering rack OEM springs Integra trailing arms Integra rear sway bar (1mm thicker than OEM) Aftermarket slotted upper control arm with new ball joints 91 EX Honda Spindles Front is toed 1/8" out Rear is zero toe This problem is a bit hard to search for so I'm hoping someone who races a Honda has come across this. Quote Link to comment Share on other sites More sharing options...
