SOLD!!! GREAT DEAL - 99 Integra GSR $7000 HC2/PTB/ST4
Posted (edited)
For Sale:
1999 Acura Integra with B18C1
Clean build, sorted, fast, reliable racecar
$7,000 OBO
Fresh build in 2012 with a stripped RS chassis (no sunroof!) down to every nut and bolt. All damping and asphalt removed.
Can be raced in:
NASA HC2, PTC, ST4, TT
Background:
-- Debut at 2012 USTCC World Touring Car Championship race in Sonoma
-- NASA Norcal TTE Thunderhill track record holder (with junk LS test engine)
-- Raced only 3 times since completion.
Engine/Drivetrain:
-- B18C1 blueprinted and balanced with OEM internals
-- 191hp/132ft-lb at wheels
-- ARP fasteners
-- Hondata S300 mildly tuned for longevity
-- JDM Type R tubular headers
-- Custom intake with minimal bends
-- Apexi Exhaust, good enough for Laguna quiet days
-- Oil Cooler with remote oversized filter
-- 3quart Canton accumulator located in trunk
-- 99 Civic SI B16 tranny with Quaife LSD
-- ACT HD clutch with lightweight flywheel
-- redline grease packed wheel bearings
-- NGK plugs and wires
Suspension:
-- Koni 3011 custom valving
-- 700/1100# eibach springs
-- Stock front swaybar (disconnected)
-- Front roll center adjuster
-- Full spherical bearing front LCA
-- Spare front LCA with energy bushing
-- Skunk2 Pro Series front camber kit upper arms
-- Spherical rear trailing arm and control bearings
-- Blox rear upper camber kit
-- ASR 32mm hollow rear sway bar with subframe reinforcement brace
-- Full ARP studs
-- 15x9 25mm offset with Hoosiers R6
-- 17x8 35mm offset with Nitto NT01 (USTCC size)
Brakes:
-- NSX front calipers with large legends rotors
-- ABS eliminated, full RS brake lines
-- Carbotech front pads, PFC rear
Exterior:
-- Honda championship white
-- full 99 front end
-- Painted Type R front lip included
-- HID low and hi beams
Interior:
-- Mike Lock 8-pt cage with chassis integration plates
-- Stripped interior, painted
-- Carbon fiber rear hatch with lexan window
-- Wired for radio with antenna
-- Momo composite seat with IO Port back brace (ignore pic with seat insert)
-- AIM XGlog Dash/Data logger
Car without driver: 2,200lbs
Please email Tommy for more details, [email protected]
