2003 Nissan 350Z Enthusiast
Salvisol
 Share
Vehicle Details
Price: $4000 obo
Mileage: 107,700
Vehicle Location: Decherd, TN
Vehicle Title: Yes (MS Title in my name)
Seller Name: Sergio B.
Email: Undiaf1 at yahoo dot com
Hello everyone. I need to try to reduce some of my car count. I have a 350Z that I'm putting up for sale. I bought this car as a fixer upper with the intent of making it a track car but have not gone super far in the build. The car was not driven from October 2014 to October 2016 due to an engine misfire issue. I have owned the car since August 2015. The car is currently fixed and runs and drives.
Vehicle Condition:
-The vehicle has two accidents in Autocheck/Carfax history (One listed as Front RH, and a second accident listed as rear impact)
-Panel gaps are visible in front and rear most likely due to previous accidents
-The car drives well enough to be a daily driver. I have put ~14k miles on it since October 2016.
-The clutch still grabs well to allow for good acceleration
-Old Toyo Proxes TPT tires in stock sizes with plenty of tread but build date in 2009
-Needs rear diff bushing replaced
-Has synchro grind on 5th and 6th gears when shifting quickly
-Needs windshield replaced
-A/C is not functional. it might be the IPDM board
-New ball joints in the front suspension would be a good idea. Some of the joints have opened up and some have age cracks and will open up soon.
-Has 350Z axle click. TSB fix will have to be performed to fix click
-Slight differential whine when cruising in 5th gear at highway speeds
-Upper and lower oil pans need a reseal
-Front timing cover needs a reseal
Recent Parts and Service:
-4 Wheel Alignment
-New rear differential gear oil (Valvoline 80W-90 Synthetic Blend)
-New Copper Spark Plugs (All 6)
-New Hitachi Replacement Coilpacks (All 6)
-Stock fuel injectors cleaned by Deatschwerks
-New transmission gear oil (Redline MT-85)
-New vacuum and water hoses that attach to intake manifold
-New Nissan Valvecovers
-New Valve Cover Gaskets
-New fuel rail O-Rings
-New NTK O2 Sensors (All 4)
-Firestone Indy 500 Tires in 235/50/17
-Motegi MR118 17X8 Wheels on all four corners, +32mm Offset
-Stabilizer bar connecting rods are brand new front and rear. Genuine Nissan.
Pictures can be seen at the link shown below.
https://drive.google.com/open?id=1Uvtg4-zcHuUd70jSU6_t3-9MaV28eHX9
  • 10 months later...
  • 8 months later...
Added new pictures to the picture link. The car is currently fitted with Motegi wheels and Firestone Indy 500 tires.
Updated vehicle mileage on first post.
Updated vehicle location on first post.
New Prices.
$4000 For car with Motegi Wheels and Indy 500 tires
$3500 for car with original wheels and old Toyot TPT tires.
 Share
