1995 Mazda Miata street/track ready car
2bars
 Share
Great for someone wanting to start doing track days, hpde, time trial etc.. Rebuilt title. 175k mi. Car is reliable and setup with easy handling. Can be had with soft top or hardtop. Blk painted nb wheels or 15" Rota subzero wheels. Has many new or newer maintenance or performance parts as listed below.
Went to Texas World Speedway twice in 2016 with zero issues. Ran in TTE. Will have fresh inspection and registration sticker after this weekend. Will be at the Nasa event at MSR-Houston on Jan 28th,29th If you'd like to see it in action. Price will vary depending on parts/wheel set wanted. $2500-4,000 obo. Call or text John at 36one-2four9-three11two
1995 Mazda Miata 1.8l
175,000 miles
rebuilt title
power windows, mirrors, steering and cruise control. Cold ac/hot heater
parts replaced in October 2016:
fresh rotors with EBC Yellowstuff pads front and rear, brake fluid flushed and replaced with ATE super200
K&N drop in air filter
Stainless axle back muffler
coil pack, valve cover gasket, CAS o-ring, NGK Iridium spark plugs, Mobil1 synthetic transmission fluid. fresh Valvoline full synthetic oil in April, Oct., and Jan. (replaced before each track day)
Parts installed/replaced Jan. 2016:
Ngk plug wires, new clutch slave and master cylinders, Modified Hard Dog roll bar, Installed alum. race seat, Schroth harness. Removed newer vinyl soft top, Installed oem hardtop
Had cheap replacement steel hood, replaced with oem Aluminum hood for weight savings. Hood has some hail damage and is dark blue/green color.
Mazdaspeed Bilsteins with Ground Control coilover sleeves. aluminum extended top hats. Grip Royal wood steering wheel with Momo hub adapter.
Call for Pics, I will try to add links here. Will get some video from the event this weekend.
 Share
