NEW GTS Website is UP!
Michael G.
 Share
  • Members
The new NASA GTS Website - https://gts.nasaseries.com
As per 2017 Rules - with the new website comes Mandatory Dyno Upload. From this point going forward every driver participating in the NASA GTS will be required to download all of the mandatory compliance forms on to the GTS website.
As always - forms required :
1. Dyno Graph
2. Table of HP/RPM values in 500 increments
3. Calculator showing Minimum Weight.
4. Dyno Declaration Form - filled, signed, dated - valid for 12 month from the Date.
We will still encourage drivers to have a printed format available as a back up.
We recognize that in few Regions where the Dyno is traditionally present at the first event of the season, many drivers take advantage of that and use it for the compliance. For those the download might be delayed until the event time.
Please, try the upload soon and reply with any issues, questions or comments.
Michael G.
GTS Nat. Dir.
  • Members
In regards to announcements - we use all possible sources to reach as many drivers, Forum, FB, personal contacts, etc.
Just to clarify - the best way to log in would probably be a link to the main NASA site using the same log in as for that site. But since the sites are built on different platforms - that would require the resources of high $$$. Using the FB log in offered the simplest alternative with the least cost, considering that most drivers already have the FB log in. There were also time constraints, since the goal was to release new sites for all NASA classes around the same time, but GTS site required more development due to the upload and calculator.
We requested the alternative log in option, most likely through Google and/or manual - email/password and expect that to be available soon. Meanwhile, you can create a FB account without uploading any info, just for the log in purposes, which will be sufficient for the log in to GTS site.
I understand that some drivers may prefer not to have the FB account no matter what, and we hope to accommodate soon with the optional log in.
We also hope to resolve the issue of multiple downloads per driver in case of different set ups / multi class use of the same vehicle.
I am sure there will be bumps on the road to overcome, we just need to be patient and work together. Even though the download is mandatory per Rules, we will use the discretion and flexibility until all of the issues are sorted out.
Michael G.
GTS Nat. Dir.
  • Members
Here is the message from Roman V. - NASA IT dept. -
"All FB login does is it takes your email address from FB and automatically creates an account for you on GTS website. If you want to login in with regular username and password afterwards just go to https://nasaseries.com/wp-login.php?action=lostpassword put in your email you use for FB and it will email you password reset instructions. You will also receive your username. We added username/password field to the sidebar."
We also added Compliance Pack 1 and 2 - in case you need to download more than 1 dyno - either for 2 different classes or slicks / DOT.
Michael G.
GTS Nat. Dir.
 Share
